Should be here in a week or so. Will post pictures of whats in the box, but wont be installing for about a month. heading up to royal blue for memorial day and wont need my big mudders until i get back.
The adapter collar in a regular kit is too big by a hair. The Honda adapter is the proper size and goes 2/3 of the way around the plate the ball joint fits. I tried using the sleeve in the litany got the ball joint pushing a lil side ways and popped the cap off of it. Wish I'd taken pics....so a normal parts house ball joint press wont do the job? if so please explain the issue.
what size sockets were those? 6 or 12pt?
Put mine in this past week. Minor problem with ball joint replacement but overh all went went well. End result was very satisfying. I run outback 30s and did HL lift and arms .... No more rubs!!
I got 32" tires on mine and was rubbing so i end up buying 2" spacers and it solve the promblem
So u have a 2.5 lift. An the high lifter a arms and still rubbed so u put wheel spacers on?I use 4x137 spacers and lug nuts 10x1.25
Yes i have a 2.5 inch lift and no aftermarket arm just the spacers 2" i bought the 4x137 and it fit great on my p1000 no rub
And sorry i meant to say Wheels spacers 2" what i got
How much wheel base does this add? Does the width stay the sameI used a shop press and some sockets......
But if you have access to the proper tools, that would probably be better to use.
Sent from my iPhone 10s
