Question
G
Gascop
22
55
Columbus Ga
  1. Talon X4
I was wondering if it would hurt anything to put the same width tires on the stock rims I want to go up to a 30' tall by 10 ' wide on the stockers ?
273,541
Won't hurt anything running 30" tires on oem wheels on a Talon.
Reactions: TripleB
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Welcome!
Nope, wont hurt anything, many Talon owners have done it. The only thing to note is that your stock front rims are 6.5" wide vs 8" for the rear so with 30x10x15 tires all around the tire height will slightly be taller on the front. You can run a couple of psi lower in the front to keep the tire height relatively the same height. If the tire height combo is drastically different (2-4"), it will trigger a I-4wd light that has to be reset manually.
Lots of good info in this thread by @CID to read up on. Talon - New Talon Owners - First Things to Know and Check
Reactions: CID and TripleB
G
Gascop
22
55
Columbus Ga
  1. Talon X4
I know tire sizes run small and haven't actually measured mine yet the indicated stock sizes are 28's on a 2021 1000x4
273,541
Yeah, I corrected my post. I was referring to P1K not Talon originally.
