P700 Questions on adding lights, ect.
Diverguy
Diverguy
120
321
PA, USA
I'm bringing my "18 700-4D home from my cabin this week to add on some accessories...winch, fender flares, reverse light, rock lights, bumper light bar, and dome lights. I already have a 50" light bar at the roof line.
I'm planning on a switches for all the lights, except the reverse light which will go on when in reverse. I am also running wires from the battery to posts I'll set up under the hood.
Will I need to use a separate relay for each application? I'm going to use LED for all lighting (duh!), so voltage draw won't be bad. I want all lights to work only when the key is on.
I'm a woodworker, not an electrician, so I'd appreciate any tips or help. Thanks so much in advance!
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Are you saying, one switch to run all the lights when the key is on?
Diverguy
Diverguy
120
321
PA, USA
No...separate switches for each. I'm not sure if I need a relay for each one...I have the accessory harness that splices into the lighter plug for the lights and winch, as well as the reverse beeper harness for the back-up light. I can run the reverse light direct to battery, as that will be switched on by shifting into reverse. The bumper light will be used for foggy/misty mornings when the light bar is too high and too bright. I'm planning on two 9w led rock lights for interior dome lights, so they have minimal draw. Rock lights will be 9w led amber lights at each wheel. I get onto some pretty nasty trails in pursuit of filling the freezer, and lights at the wheels would help a lot on my way to and from my tree stands in the dark. They will only be used when needed, or for parades now and then.
Sheepdog
Sheepdog
67
70
Lyles Tennessee
it was recommended to me by some of the great members here back when i was going to install my led lights and accessories that i should use a relay for each light circuit, which I have. The only light circuit that i didn't use a relay on is my reverse light that i hooked up to the reverse harness but I did install a inline fuse for that circuit. I am running a dual battery setup and secondary fuse block, switch panel ect,so for my application, using individual relays made sense. Relays are fairly simple to hook up. I'm sure some of the smarter folks then me on here will have the correct answer for your kind of setup.
