P500 Radiator Fan not Engaging
105,595
For some unknown reason my radiator fan isn't working and the P5 keeps overheating. Any suggestions? Thanks.
lee
lee
Village Idiot
2,403
13,606
Springfield Ohio
Dose the fan work? Jump it to make sure the motor is ok.
Is everything plugged in ok? Not likely to suddenly unplug itself unless you had stuff disassembled.
The fan is controlled by a little black box located under the passenger seat, make sure the smoke didn't escape from the control module.
As I recall you are on the road.
When you go to test the fan hook up a temp jumper with a switch.
There are a few threads on here discussing this.
Also supporting member has access to a wiring diagram.
Use the jumper untill you are some place to get parts or can get help trouble shooting it.
One last thing, don't curse the Honda engineer that designed the fan, I'm sure he would try to help you if he could.
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,490
0F0C5110 BACD 451D BD8C DE459F934B95
@100Acre ,did you extend the vent line? May not be related but just curious. Also, is fuse ok.
1A4F1445 0E9D 4D8D B16C CE9D3C7CB0F0
105,595
105,595
@JCMINIS
Reactions: JCMINIS
105,595
Where do I find it? I wish I were better with computers and mechanics...
HUCK
HUCK
1,047
2,319
ARIZONA
Check the fuse first
Have had this happen twice in the last 2 months to others I ride with . Both had blown fuse .
Reactions: Mudder and 100Acre
O
oldgasser
53
77
Arizona
I had a similar problem with my 1000-5. I wired a manual switch in parallel with the fan controller. Now I can turn it on manually if needed.
Old Gasser
105,595
I switched the fuse with the spare and the fan still did not come on when I turned the key. I thought it normally comes on with ignition, or does it only engage when the engine is hot?
JollyJoker
JollyJoker
92
192
Minnesota
It only runs when the engine calls for it to run (when it is hot). Was the fuse you pulled out blown or was it ok?
Reactions: 100Acre
105,595
Looked fine but I switched it anyway just to make sure
HUCK
HUCK
1,047
2,319
ARIZONA
Only runs on demand . Let it warm up . We had one that we replaced the fuse on and found out after we got home that the fuse we thought was bad was good , so I put it back in and it worked fine . I guess the fuse was not seated or ......./?
Reactions: 100Acre
