Rattle in Talon
PhilCod
PhilCod
354
729
Indiana
A couple of weeks ago a few of us went to Virginia to ride the trails since they were open. We were right on the WV line and honestly spent more time in WV on the Outlaw trails then anything else. Anyway, a rattle started somewhere on the drivers side by my door or right behind it. No mater what I did, like holding the door or roof made it go away. I went over the Talon when I cleaned her up and I can't find anything loose. It only rattles when I'm hitting bumps, so it's not an exhaust issue. I have 357 miles on her, so it doesn't seem to be something that is worn out. Any ideas? Useful input please....
Reactions: Isaiah
906UP
906UP
14,391
136,716
da Yoop
Mine does this on the passenger door, drives my wife crazy, haven't been able to track it down yet
Reactions: Isaiah
5,484
25,244
When I unloaded my brand new Talon, it rattled badly. When I added the lower doors, I had the door skins off and adjusted the latch tighter. Later I figured out that the doors have a 2 stage latch like cars - I wasn't shutting the door tightly. 🤭
PhilCod
PhilCod
354
729
Indiana
Could be the shocks topping out, not uncommon.
That's a good point. I know these Fox shocks have the tendency to leak out all the air. I do have new Schmidy Racing caps for the shocks with the valves, I just haven't put them on yet. I take a look at the door latches as well. Or maybe I'll take the door off and see if I still get the rattle.
Reactions: Lil_Steve and CID
F
fartsalot
223
337
Near the Kansas Nascar race track
I kept hearing a annoying rattle in behind the passenger seat back it was a ongoing thing. I took the seat out and found a shot gun shell from when I caught a buzzard eating a dead rabbit in the road. I have the top off and I just stopped and stood up and shot the dam buzzard.
bjniceguy
322
431
Iowa
my rattle was the end of the Tusk Jack (had put on a hex adapter for socket). Once found it, just add a rubber washer and gone
IDIOT
IDIOT
280
755
Kingman, Az.
I have that rattle on the passenger side and i think i found it, not sure what the arm is called but it is the arm or link that runs just above the trailing arm and then bends inward slightly where it bolts to the chassis right behind the rear fire wall. There is a round shoulder at the head of the bolt that fits inside the bracket on the chassis and that is what is rattling. Not sure what the remedy will be but if i get it to stop i will share it here.....
RB3offroad
RB3offroad
1,712
4,815
Tempe, AZ
yes there is defiantly a rattle behind the door. We are looking at it!!!!!
Reactions: Montecresto
906UP
906UP
14,391
136,716
da Yoop
Went out and drove the doors off it and NO rattle...so far
I had a rattle coming from the passenger door, a 1/2 turn out on the rubber bumper thingy below the latch solved it.
PhilCod
PhilCod
354
729
Indiana
My rattle was a bad shock on the drivers rear side. It was under warranty and it's been replaced. But I would call it more of a banging sound. I got her back and took the shock off and changed out the tender spring to the bandit, and put the reservoir caps on and had it filled with nitrogen. All good since then. But I do have some door rattle. I need to adjust those bumpers.
Reactions: IDIOT
IDIOT
IDIOT
280
755
Kingman, Az.
Here is a pic of what was rattling on mine and i pulled the bolt out and covered it in grease and tightened the hell out of it with a 1/2 inch breaker bar and a long boxed end 17mm wrench. I have 2 rides on it and so far no rattle. Now to see how long it stays that way.
IMG 5985
RB3offroad
RB3offroad
1,712
4,815
Tempe, AZ
that is where ours is
wojtalon
wojtalon
5
Golden, Colorado
There is an apparent rattling noise that sounds like it's coming from the suspension. Sounds like marbles bouncing around on plastic. Driving me crazy.
I mounted a gopro to help diagnose the noise. Take a look/listen and see if you have any ideas on what this noise is.
Is it normal? Do you hear this same noise on your Talon?
Going to check on the "IDIOTS" mention above since that's attached to the suspension, it makes sense.
Thanks,
Woj
Reactions: CID and Tedbell52
5,484
25,244
Ewww. Sounds like you might have blown a bushing out of a suspension arm or one end of a shock. It would sorta be hidden inside its rod end.
PhilCod
PhilCod
354
729
Indiana
Mine was the shock. I have side bars, and I could jump up and down on them and the shock made the noise. My noise was also right at "head height" when sitting in the Tallon. And it was more of a "banging" sound when the shock rebounded.
5,484
25,244
Here is a pic of what was rattling on mine and i pulled the bolt out and covered it in grease and tightened the hell out of it with a 1/2 inch breaker bar and a long boxed end 17mm wrench. I have 2 rides on it and so far no rattle. Now to see how long it stays that way.View attachment 215213
After seeing this photo, I checked mine, it isn't a good, tight connection. I don't know exactly what type of joint this is but as I get more miles, I can see it becoming a noticeable clunking rattle. At this time, I'm only able to make the passenger side rattle a little bit but I'll check them from time to time.
Reactions: IDIOT
IDIOT
IDIOT
280
755
Kingman, Az.
Now i'm wondering if i have fixed it for good or will it start to rattle again at some point. The driver side does not do it so that tells me there must be a way to fix the passenger side. I did notice that the bolt on the passenger side was not as tight as the one on the driver side.
Reactions: Tedbell52 and CID
Come up with anything on that yet. I have the rattle in the doors, and have adjusted them very tight, and it seems like it’s the door skin that’s rattling......🤔
