I bought this 2016 1000-5 2 years ago used and the previous owners wiring was questionable at best. It was a rats nest under the hood and wires spliced into wires spliced into more wires. I added a couple light bars that didn’t help the situation. It was time for a change, fix the mess and and protect it from and voltage issues. This is still an ongoing project so I’ll update as I go but this was when I started pulling wires from under the dash:
I wanted to add a second battery and isolator then decided to do a stinger relay and fuse box.
First the accessories I’m running and why it’s been a nightmare:
Winch
Heater
Windshield wiper
Blower
Radio
Light bar (wire with high beams)
Pod lights on front
Rear back up pod lights (wired to reverse and switch)
Turn signals, horn, hazards.
Plus I’m going to add some interior lights.
Not a small task but I have a little OCD and the wiring has driven me nuts since I’ve owned it. It has a Honda switch panel for the heater and wipers. All of this ran off one battery, some tied into ignition power some not.
There was 7 wires going in to negative and 5-6 going to positive plus wires spliced into those wires.
Here is the previous switch panel:
None of the lights works on the switches which is really annoying so wanted to fix that and the USB port on the right of the radio didn’t work so I wanted to replace it as well. So I bought a PBR panel to replace it. Here is rewiring the switches:
Here’s a pile of the wires I removed:
Here is the under hood so far. Waiting for my Battery to show up tomorrow to install, then will mount the isolator and stinger but I’ve added a ground to the frame and it’s all ready.
Here’s what the under hood looks like so far:
I had a major problem as I was testing the relay and fuse panel. I hooked the relay up to the battery and ignition power from the #5 slot on the fuse panel to test the fuse panel and make sure everything worked. Everything would turn on with the ignition fine but when I turned off the ignition the dash and accessories still had power. I had to unhook the negative to get the dash and accessories to the shut off. I rechecked all the wiring, tore apart the dash, pulled fuses and wires and cut wires, nothing was fixing the issue. It was backfeeding to the ignition. After hours of research and trying a bunch of different things, I finally figured out the relay was bad. I did the old trick you use on your starter when it fails and tapped the relay with a screwdriver and the damn thing kicked off. Brand new relay. So anyway getting a new one sent Wednesday. FM
I bought every part I could off this forum and appreciate all the info and knowledge I’ve gained.
Here is the dash so far. Waiting on a couple switches.
Hoping to finish this by Wednesday.
Winch
Heater
Windshield wiper
Blower
Radio
Pod lights on front
