Love the strongmade basket.Something like this? Strongmade rear basket...
I too, love the Strongmade - EXCEPT that they didn't shape the rear portion to conform with the rack. I'd buy one in a minute if they'd finish the shape up. The Strongmade box doesn't really look like it was built for the P-500, but rather a knock-off of a box built for some other UTVs.
Not having a box on back is a major drawback for what I want to use the P-500 for, and that is for working around the place, which involves hauling tools, chainsaw, etc. Not having a decent looking box will not lead me to trading my new P-500, but it may lead me to building my own box.
If anyone has a lead on a correctly shaped box for the P-500, I'd sure like to know about it. Last choice for me would be to buy the plastic cargo tray Honda sells, but again, that would be the last choice.
I agree with that, it would give more storage and look better! Making your own is the best though. IMO.Interestingly, I contacted Mike Crochet @ Strongmade asking about the possibility of building their Model 574, and perhaps others, to fit the contour of the Pioneer 500. It looks like a simple modification in the manufacturing design, but making it actually fit like it belongs there is important to me, and I'm sure to others.
If Strongmade decides that they can or will make a cargo tray like I suggested, I'll sure post it. I did tell Mike that IF they do, put me down for the first one!
My thread was on the other p500 forum. link-disallowed. Search strongmade group buy. I'm about ready for a new better bed. But I'm not spending $700 on the strongmade bed.
I sure agree, I'm not in for a $700 cargo box either. The box I'm looking at, the Model 574, is $230. The box from eTrailer is also nice, and of course, much cheaper.
Maybe I'm too particular, but what I 'want' is a cargo box that follows the outline of the P500 rear rack, not one that's squared off and extends out back. On the other hand, what I want and what's available (at a decent price) seem to be two different things.
William, I am glad that you ALSO contacted Strongmade. I certainly could live with one with the taller front panel. That part doesn't bother me one way or the other. I do believe they could make a box contoured same as the Pioneer 500 rear rack. Squared off and extended beyond the rack does bother me.
I've already built a box out of plywood covered with 3/4" rubber horse mat with cad-plated tie-downs, chrome acorn nuts, recessed bolts, etc. It is contoured to the Pioneer 500 rear rack. If someone needs a template, I certainly have one. BUT - I'm also not satisfied with the wooden version and will be buying a metal one from someone, be it Strongmade or a custom welding shop, or somewhere. Not wanting to sound hard-nosed, but simply said, I want what I want and 'close' isn't good enough. Aren't we all like that on some things
With that same rack design being installed for 3 years already, I think it would be a good seller. I'll wait a reasonable amount of time and see if Strongmade also thinks a correct formed box is a worthwhile endeavor. If not, I'll go on my way...
View attachment 11258 Built my own, it wasn't too tough and allows you to build in any specs you want. Came out looking pretty clean... View attachment 11259 View attachment 11260 View attachment 11261
Fantastic job Slim! That's exactly what I have in mind. Any info on materials, clamps, etc. would be appreciated; that'd save me a few trips to the hardware store, which is 25 miles each way for me.
PS And welcome to the P-500 SxS Club. You've already become a valued member
Thanks, Here's the process I did
I measured the rack demensions for the bottom outline, and top outline, than factored on 7" post's for the corners.
Then went to local steel shop, picked up 1" square tubing, and 1 sheet of expanded metal(4'x8').
I cut the square tubing into lengths that I needed, then tacked them together using a mig welder.
Once I got the bottom frame tacked, I welded the bottom frame, I then welded the post's and top frame together.
Then I measured and outlined on the expanded metal for the bottom and sides
I took a hand grinder with a cutting wheel and cut out the expanded metal
Then I tacked the expanded metal to the frame on the bottom and sides
Next I grinded all the welds, and then painted it black
Last I just went and got some u clamps from hardware store to bolt the basket to the rack.
I am very happy with it, before I built this I was looking all over for one and couldn't find anything that I liked and looked clean.
I also built one out of wood, and It worked but it made the pioneer look like a golf cart and I hated it...
Cost of materials for the metal rack was about $120.00
Wood box was about $75.00
Figured I'd include pics of the wood one too
Hope this helps...
Same story here, if I knew how to weld then I would build like post #12. So I went with Curt and can't be happier. Check out my build post to see how it fitsTorn between the Strongmade (post#2), and the etrailer (post#7).
Both welded steel, powdercoated, about the same weight, indicating similarly strong, assuming equal craftsmanship.
Strongmade is $230, etrailer is $95.
I'm a big believer in "it only hurts once when you buy the best", but is the Strongmade basket better?
If so, in what way?
(Dang, I miss the days when my best friend was an oilfield welder and master fabricator. His idea of a great Sunday afternoon would have been me buying the beer and keeping him company while he built the perfect rack out of shop scraps.
Joe
Bring the beer and meet me at my lake house this summer sometime and we'll weld you up one!Torn between the Strongmade (post#2), and the etrailer (post#7).
If so, in what way?
Joe
Same story here, if I knew how to weld then I would build like post #12. So I went with Curt and can't be happier. Check out my build post to see how it fits.
Looks great, Solrus. Thanks. That'll work! Cool rig, btw.
574 - Rear Basket Rack For Honda Pioneer 500 2015 - For Honda - Rear Flat Basket Racks - Basket Racks - Strong Made ATV & UTV Accessories
Joe
