P700 Front frame openings
swsebek
swsebek
2,854
5,828
pa
IMG 1939
I keep my machine pretty clean and checked over but last night I found something that surprised me......I bought a frame plug kit and one must have bailed off on me....look at all the crap in there just holding moisture
Reactions: Eltobgi
Gator
Gator
The Most Unknown Member
2,471
10,350
Louisiana
Mine must look really bad. I need to look at mine. Maybe weld some caps on. Or some kind of accessory..... hmmm
Reactions: Tflynn
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
View attachment 44434 I keep my machine pretty clean and checked over but last night I found something that surprised me......I bought a frame plug kit and one must have bailed off on me....look at all the crap in there just holding moisture
When i put my plug in I sprayed wd 40 in the frame because water will still get in. I put super glue on the plug before I put it in and make sure you don't get the WD 40 at the end.
Reactions: Tflynn and swsebek
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I'm afraid to look at mine! Welding caps is probably the way to go.
swsebek
swsebek
2,854
5,828
pa
I ended up cleaning inside tubes and wiped heavy grease all over inside and siliconed the ends on.
