I just finished them this morning.. I wired them on a hot switch for anytime use.I find it really handy to be able to turn on the rear lights to use as work lights.
I used a relay to reverse polarity of the ground switch - like cummins explained and used a three way switch.
Reverse light / Stealth (@JTW) / Work light.
Maybe a winter project for you guys?
What's that knob switch in the middle of your dash do? Mine don't have it.I just finished them this morning.. I wired them on a hot switch for anytime use.
View attachment 25240 View attachment 25241
The ground switch is a solid ground based off where the gear position switch is at. Each position sends a ground to the computer. This wire is just a tap into the R gear position wire from factory.
Not positive if the 500 uses ground trigger for backup alarm but if it does like the 1000
I originally thought of wiring them on reverse but after much consideration I'm not sure I want them on EVERY time I back up. I mean what if you're someplace you shouldn't be and have to back up? It's like a game warden beacon!!
Manual/auto on the transmissionWhat's that knob switch in the middle of your dash do? Mine don't have it.
5.7amp sounds about right... it is typically Watts/Voltage. So 60W on a 12v system should be around 5amp.I'm in the process of finishing up some reverse/rear work lights and was just wondering if any one knew how many amps the reverse switch can handle. I am putting 2 10w led flood lights on the rear of the rops. And then 4 10w eagle eye button lights on the rear emp bumper. I tried to measure there draw with an amp meter. And have a rough and dirty guess of 5.7 amps for all 6. Do you think that a relay should be used to try to make the switch last longer?
That wouldn't come at all without being in reverse. You couldn't use dash switch instead of reverse. However it would allow you to turn off the light in reverse.
You would need to wire up a dash switch like normal. Wire up this relay of the neg trigger from the reverse and post 87 into the positive between the dash switch and lights. I think it's about the same way you explained it, except you need the lights on AND reverse to trigger the relay.
I didn't do the stealth mode with mine, but all it would take is cutting the jumper between 30 and 86, then power 86 off the illumination circuit. Dash switch is powered off PDM and then hooked to my pods. I might have miss read the way you would wire up the relay. I ran the ground for the back up alarm to the dash and post 85. Post 30 gets fused 12v. 87 ties into my positive between the switch and pods.I posted and got to think about it again but no you'd still couldn't turn it on by switch only. You'd have to tie in after I believe
We only run the light bars when we need them, but headlights day or night. Just a quick glance in the mirror to see if the guy behind is still there or if it's time to stop and have a beverage.
Useless?? How so?Honestly for us it's waisted power with the 52 inch and the 168w bumper lights on because they become useless. We do run them sometimes but not often enough to trigger something on.
We're never concerned about stealth mode ourselves so both yours and ours are the same. Reverse lights, or switched on.
But that's a good way to go on switching for reverse for many and a solution for @JTW. Thank you.
