P1000m5 Relays and rocker switches
Seadonist
Seadonist
380
1,117
New Orleans
I’m wiring my LED’s and I want to run them through relays and then to my XTC rocker switches. I currently have my rocker switches backboned/ daisy chained together without any relays hooked up. My question is if I run relays do I have to run each rocker separately to it’s own relay or can I still daisy chain them together? Thanks
Reactions: Lady01
66,167
This would depend on the loads.
You can chain them together as long as you dont cross the limits.
Ex. 20A fuse, 20A relay, 20A switch.
You can chain 3 (maybe 4) items at 5A each.
Seadonist
Seadonist
380
1,117
New Orleans
The relays are all 40 amp and I think the rockers are 20 amp
Reactions: Lady01
66,167
Ya,
You cant pass more than 20a through a switch. Id say under 15a.
But.. you can jump the power from the relay to each switch,
then the output of the switch must be under 15a.
Reactions: TripleB
66,167
I think I'm guiding you in reverse..
2 options.
Relay powers then switch, then the LED
OR
The switch triggers the relay, then powers the LED.
These are totally different in how they are wired.
66,167
If your light requires 40A, it should be the second option.
low amp power, powers the panel and the switch. (this low amp power can be jumped)
The switch then sends trigger power to the relay and says "turn on".
Relay powers the LED.
In this case, each high power item will need its own relay.
Seadonist
Seadonist
380
1,117
New Orleans
All lights are either pods or rock lights and I think they are 15 amp draw
Reactions: Lady01
bumperm
bumperm
1,889
6,743
Gardnerville, NV
You can have all the switches wired to a common buss, and the relays as well. I'm assuming that's what you mean by daisy chained, (although the term daisy chain normally refers to "in series".
Let's assume all the switches have a common ground to their NO (normally open) terminal. The relays have a common positive bus connecting to one side of the relay coil. The other side of the relay coil goes to the other terminal of the switch. When the switch is closed it applies a the ground to the opposite coil terminal of the relay, causing the relay to energize. This changes the relay contacts from NO to Closed or from NC to open, depending on which contact terminals you are using or need.
Course you can flip that around and have the positive buss on the switches etc etc. Advantage of using relays is you can use thinner lighter wire from the switch to the relay coil. And also the relay can be selected for it's current carrying capacity.
Relays are not a panacea for all wiring needs. For lower current devices they many add unnecessary complexity and failure points for no real benefit. Relays can also generate an inductive kick (high voltage spike that can damage sensitive components), when the relay is deenergized. For critical apps, a diode is placed reverse bias across the relay coil to absorb the voltage spike.
66,167
Pods and rock lights are no where close to 15a. More like 3-5a.
So, you can "daisy chan" those like this.
key-on Relay -> Switch1, switch 2, switch3.... -> then to Lights
Thats how I build my panels.
Reactions: Worse1 and TripleB
Seadonist
Seadonist
380
1,117
New Orleans
You just told me exactly what I wanted to hear. Big thank you, Hondasxs!!
Reactions: TripleB
