Well.....this thread might only end up being 2 parts build-related, 1 part "let's see if this works" and 1 part shameless attempt to learn from others' experience without having to start a bunch of new threads. I do a lot of searching and reading, but have found that most folks are in the recreation side of things. Most of my needs are on the work side. But the build stuff will be a little of both because it's more fun to build for trail riding....at least I think it will be.
So far: despite having this machine for almost a year, it has gotten limited use. I've got property that I'm planning to build on this year so most of it's use has been as a motorized tool box and for skidding logs. I've got the Honda roof, a homemade bed mat cut out of stall material from Tractor Supply (thanks to the member who gave me this idea, wherever you are) and a radiator hose under-hood snorkel (idea stolen from @Dragon21, thanks). That's it for "mods" so far.
For Christmas.....my wife bought me the Impact Implements hydraulic "1-point hitch" and a box scraper....so I'll be able to do some minor grading.
Finally, I've got switches on order from OTRATTW and a panel from @mystic1219 and all the bits and pieces to set up a dual battery system. I'll post more on the details of what I plan to do later. Should make a good winter project.
I welcome any and all constructive criticism and suggestions. Thanks in advance for that. With any luck, it'll also help someone that's looking to follow a similar path. More to come.
