P1000m5 Rock Donkey v2 Long Travel
I have the same volt meter installed in mine. I have a battery switch where I should switch from the factory battery and the auxiliary battery.
The switch without a rocker will control power to the accessories and chose whether they are on/off/on with ignition forgot to order the rocker.
It'd take up another slot so I figured I'd just get a second meter.
Reactions: sharp
3759106d0c237de9b337ed192934f805
I'm at a traffic light don't text and drive.
Are you pulling an all nighter?
You're going through the mods at a fast pace!
I've had these planned for a while, want to get it done so I can start riding and stop tinkering. Seemed like all I ever did on my 700, I had JUST gotten it the way I wanted it when Honda announced the 1000.
Nope I'm done for the night.
Still have front doors, skid, bilge fan, HAM radio, fire extinguisher, and wiring left.
Wiring is gonna be the long one, can't finish skid till I run battery cable from under seat to under the hood.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Roof/mid panel
Reverse light
Front/Rear camera
Switch Panel
Dome lights
28c418373564d36e6f1598d2a937fe64
162d5faff9c89584e50ba3969dd8a31b
67107e90e7e86ec93f2b5ad12c416b0c
F090a46dbb51dd866a83c00f6ec57083
75e1f6c06e13504152498679ee254242
79999b2f5b89a012f01f8fe2dfc90083
Cbae63167d75364319776976a822fe09
Test fitting the Optima
There's a bar right under, front to rear of your battery. I used 2 long J bolts/stock battery hold down/ to bolt the battery down in that spot. Die grinded a clearance slot in the skid plate to put the J bolts in.
Similar threads
