Rugged radio install
Huntndogs
Huntndogs
203
1,312
San Diego, Ca.
For anyone who has installed a rugged radio and intercom setup, how did you cut the back of the dash? Any pics of the cutout area? Have all the cables run and the dash plate should arrive Monday. Thanks in advance...
208,729
Didn't cut the dash, just mounted it in the large cubby hole and drilled a 1 1/8 inch hole in the back of the cubby hole for the wiring, but that's on a P1, happy slashing. Can you not mount the radio to the top front horizontal ROP? That would be better than slashing your dash?
Huntndogs
Huntndogs
203
1,312
San Diego, Ca.
I don’t mind cutting the dash as the mounting plate looks good and it would just go with the Talon if and when the time comes to sell it. Should not hurt value any as long as it looks professional.
PaulF
PaulF
1,462
4,815
If you are using the RR mount plate, you will need to remove about 2/3 of the upper cubby hole for it to fit.
Sorry, no pics.
Dankathy
298
844
I put mine(pci) in the over head. No cutting or drilling, all cables except the power and headsets stay up out of the way. Push to talks velcro to the window net brackets. A pair of prp overhead bags give both some much needed storage and a easy way to hide all the cables. IMG 7002IMG 7003
sspeederr
sspeederr
391
661
I put mine(pci) in the over head. No cutting or drilling, all cables except the power and headsets stay up out of the way. Push to talks velcro to the window net brackets. A pair of prp overhead bags give both some much needed storage and a easy way to hide all the cables. View attachment 267132View attachment 267133
That shelf is that the one from utv source or home made looks kit prp bags as well I'm trying to figure out room for all my stuff I have a 10in table mount to top rops bar, tyt th-8600, rear view and honda bags its a bit crammed
Mounted mine on the ROPS as well...👍
DA3612D6 9ABC 46EC 85D6 D76369088495
Reactions: lowranger
Dankathy
298
844
Nothing special here, radio mount is a 1/4x4 flat bar. Mounts between the roof and the roof mounts, just slightly longer screws to hold the roof down. Prp bags fit well, some adjustment available to clear handholds, we use a ram tablet mount on the passenger grab bar. I don't want to have to be constantly in contact with the tablet, so i am fortunate that it comes with a operator- she makes pretty good cookies to!
Huntndogs
Huntndogs
203
1,312
San Diego, Ca.
Got the radio and intercom installed today. Called RR and obtained a copy of the installation instructions that I was not sent with the kit. Made all the difference in the world. I am attaching them here in case someone is curious or searches for this in the future. By the way, I made my cuts with a Dremel tool and an oscillating saw tool. Went very well.
  • Talon Mount instructions (1).pdf
Barracuda
Barracuda
94
475
53
Washington state
  1. Talon X4 LV
  2. w/Turbo
I already had the center "console area" used by the switch plate (my Special Edition has the Honda switch already install from the factory) and I had already spent quite a bit of time getting my accessory switches installed and the wiring was already done:
1641139530836
So when I decided to get the Rugged Radio I wasn't going to tear that out and start over - my switches are energized using the keyed power source which is then run thru fuses and relays to power the accessories, the switches only see a signal voltage - not full accessory voltage:
1641139789549
This left me with finding another location for the radio/intercom. After looking at my options I chose to build a box and mount them overhead with a switch and relay. I think it came out pretty clean - all of the radio system is above the roll bar and isn't visible looking from the front - so it doesnt limit visibility looking forward. The only drawback is that the radio switches arent as accessible as if it was on the dash, but I shouldnt need to use the controls much once they are set.
1641140185343
1641140225102
All of the wiring (power wires, headsets, and antenna cables) is routed along the roll bar and down the A pillars - the headsets and power on the drivers side and antenna on the passenger side, so the antenna is isolated and should eliminate any feedback. I just finished the radio and intercom install and just need to install the mic and test everything.
I also picked up a second battery, isolator, and tray which is now installed as part of the accessory system - all isolated from the factory wiring (the keyed source is the only power used from the engine battery).
1641140811528
lowranger
lowranger
513
2,747
Northern California
I also mounted my radio and intercom over head. Its up out of the way, I didn't have to cut up my dash and less chance of mud and water getting to it when riding or just cleaning it up. I went with "TheCom" radio and intercom out of Idaho, nice people to work with and answered every question right away.
I also added a second battery.
IMG 20210101 125324812 HDR
IMG 20210101 151458020 HDR
tanks
tanks
5
7
CA
Hey there. I know this is my 1st post but just got done with this! I used dremel and cut out the back of the entire box to use the plate from rugged. Sadly I can’t find this pic anywhere but i can snap a pic of how much I removed if thats helpful. I highly recomment the baja boot because the back of the radio does become somewhat exposed without the plastic box.
I relocated my lights switches with a plate To the outside of the drivers cubby with a plate and then my particle seperator to above the ignition.
50098A8A A601 4EB2 A01B 3CEAAC5D1C9C
B547986C 3859 4797 9CFB DE84D136CC78
I did a plate mount in between the seats for jacking in and then push to talks in the dash below the center cluster because I hated the loop on the steering wheel.
99E20A2B C365 4F07 B29D AB31A4D791C0
EED04923 F357 451B B8D8 C3A72CB0919B
I also made a mount for the antenna so it would sit straight up and down above the roof.
A92EA392 019D 4151 A1BD A1DB69294C91
I have had the system out a few times now with a passenger and love it!
TalonMatt
TalonMatt
71
148
WA
I ended up mounting mine on the roof. Ended up being super easy to run all cables and has worked out well!
IMG 0213
IMG 0211
115,818
The OP started this in 21’ so Id think he already decided on where to put his!😂 juat messin with ya.
But we never seen….👇🏻👇🏻👇🏻👇🏻👇🏻👇🏻
I am definitely going in dash...I will take some pics of install as I go.
☝🏻☝🏻☝🏻☝🏻☝🏻☝🏻THESE☝🏻☝🏻☝🏻☝🏻☝🏻☝🏻
Im currently Installing the kit between work and getting into my tree stand. Ill try and remember to dig this tread back up and post some pics if it, but it will deff be in my Talon build Thread Fo Sho.
Im mounting mine in the dash. You smellers must be short AF, Ive had a Swamp donkey in my overhead since 21’ Im 6’2 and that M-Fer been a sword in the side of my head for the last 4 years and it hangs higher than the radios with bracket's or a built box and I still manage to hit my head every now and again. Done with that $hit lol Hit my head enough ar work, dont need to do that during play time. You Dont realize the room you lost till you remove the box.. thats what she said🤔😂
All the installs that WHERE posted look good tho.
Reactions: Scoop
NTCPrezJB
NTCPrezJB
Retiring Member
112,827
975,773
Hidden
Keep in mind your chop top club doesn’t help your head room though.
  • Haha
Reactions: Scoop and Remington
115,818
True, that would be on the P1 tho. This is the Talon that I wont do that to.
The P1 stock is High like a paddy wagon
Chopping that 4-1/2” (NoHmo) still gave me quite a bit of room with a stock roof
Reactions: NTCPrezJB and Scoop
