P1000 Sagging Suspension
caleb7160
caleb7160
5
Anyone else having an issue with the rear suspension sagging? The drivers side is sitting about an inch lower than the passenger. My only guess would be that it's an issue with the shock. Still running on the factory shocks and the machine was wrecked and repaired before I purchased it.
We need pics... but it’s probably a busted shock if all the mounts are good and nothing is bent. Wouldn’t be the first.
208,011
Think somethings fishy about the repair. Unless it's a bent shock shaft.
Bayouownbeer
Bayouownbeer
783
1,054
Chauvin LA
Mine is same haven’t looked into yet. I have spare on that side in the bed 50lb I figured that’s what my issue is.
caleb7160
caleb7160
5
It's only off slightly but you can definitely see it. If you find out what's going on with yours, please post an update! So far I haven't been able to find anything that looks broken or out of place visually.
Reactions: Bayouownbeer
T
tinystech
Iowa
I have a 2018 pioneer 1000-5 with the same issue. I bought it from my cousin last spring (3,500 miles then) and it was only about 1/2” off but nothing was bent or looked like an issue.
I have ridden 1,500 miles since then and now my Drivers Side is sagging 1.25” with a full tank of gas and my 280 pound butt not in the seat.
The machine is all stock, only standard maintenance has been done. Should I just switch the shocks left to the right..? Will this even work? Feels like I would prefer the lean on the other side and I just use it to maintain the farm by myself.
If the driver side shocks are failing (if) I probably don’t want to switch sides. Best to put new shocks in but what would everyone suggest?
Maybe someone has another solution.
Thanks!
Robobrainiac
Robobrainiac
2,426
8,333
Thanks!
With age and mileage it would not be surprising to see a shock sagging. The rear shocks on a 1000-5 deluxe have what is called "auto leveling." basically there are valves inside the shock that are supposed to level the machine after you start moving. The rear shocks are kind of gimmicky.
As far as shock options go you can spend $700 on a set of rough country M1 all the way up to $5000 for Elka Stage 5. There are many brands of shocks with all different price tags. You need to set a budget and then do some research. Most people on here are very happy with the fox shocks. The rough country vertex are very new and some people on here would love to see some reviews of those.
4,998
22,293
Springs hold the buggy up, shocks only damp the travel. Sacked springs are common.
This Talon tender is supposed to be ~4” but sacked out over a few months because of the weight I’ve added. This is with the preload at max.
1687782540365
Scoop
Scoop
4,196
15,658
  3. Talon R LV
^ This.
FWIW, after I brought home my brand new 2021 P1K5, it listed to the left just a tad -- but enough for me and my buddy to notice.
Everything looked fine, but I assumed something was amiss with the spring on that side.
I knew I was going to be replacing the stock cushions with Fox QS3's (which would allow me to adjust the preload to ensure a even stance), so I just ignored it for the first few months. Now that I have the aftermarket coilovers on there (different springs as well), all is well.
