BOX1
P500 Shocks question
bobbybog
103
192
WV
I have a 2015 P500. There is a guy I can buy 2017 one shocks for $150. Is it worth it? Are the shocks that much better than the 2015?
bobbybog
103
192
WV
Anyone? I need this info to decide whether I should buy them or not.
luckymike
luckymike
144
322
michigan
I really don't think they're much of an improvement.save your $$$ for WE shocks
Arizona
Arizona
102
201
Casa Grande & Show Low Arizona
I put the newer stock shocks on my 2015. Starting in 2017 they went to dual coil springs. It was a noticeable improvement from the original shocks, soaked up bumps better, not much but noticeable, I'd say they helped, say on a 0 to 10 scale, 0 being no suspension, and 10 a Cadillac, stock shocks had me at 3, and the new dual coil shocks made it a 4 maybe 5. Then I went to 4 Walker Evans shocks, was disappointed they only helped about the same % as the new dual coil Honda shocks, but I called W.E. and they offered to re-valve my shocks, I sent them back, they now soak up bumps better, but if I had known they helped less than I thought, I wouldn't have spent the money, I would have stayed with the updated Honda dual coil springs, I think 4 of them cost me about $400. I have 8 Honda shocks laying around doing nothing.
Reactions: lee and DG Rider
HP5NC
252
284
NC
I just bought a 18 P5. Does anyone know right what setting the come on from the factory?? I may play with the some. Put them on the softest setting or one click up from the softest setting. But I’m not sure how the come from the factory. Any idea?
HP5NC
252
284
NC
One other thing I’ll note in regards to ride is the type of tire and the ply along with the PSI being ran. Just food for thought.
Reactions: dllj
207,922
I have a P1 and bought Elka stage 5's, price tag was $2,700, there the only shock that I could find with high , low speed compression and rebound adjustments. I highly recommend these shocks, Rooster flies now, use to just peck around. If you are so inclined to spend over $ 2000.00 for a set of four, order one set (fronts) your self and have a buddy order the rears that what you won't alert the tax gestapo! I paid over $ 300. in taxes. They came from Canada.
jmcampbell54
292
628
Texas
Check out 814utvsuspension on face book. They are making Honda shocks now.
Not my rig
4e8377e4386291e746ec04f12cecca4c
375393be436afd82b02f37e2745c1e3d
jmcampbell54
292
628
Texas
Here’s a screen shot of a install on a P1k5
1096bbb895849240e1f31f6660f28515
Become a member and ask away, answers are fairly quick and Craig will talk via phone or messenger to answer your questions.
207,922
Really confused about the strap thing, there are several shock companies, that use the straps to limit how far the shock extends. I have never seen straps used on dirt bike shocks. I think the strap technology comes from desert racing. Does the 814 have high & low speed dampening and rebound adjustments?
jmcampbell54
292
628
Texas
Just shot the owner a message, will know for sure in a few.
The straps limit the shock travel/cv axle articulation, the 814 shocks provide approximately 2” of lift on stock arms. Without the limiters damage will occur to the shocks and cv axles.
I think I’m going to be the P500 guinea pig, taking measurements this weekend and seeing what all needs to be done.
Reactions: trigger
jmcampbell54
292
628
Texas
Fb3acd20b9142edd907c408c2b6c7b4f
Craig’s response on FB messenger
3ab47765ae62b78706fb739fd14483bd
207,922
Been riding the mower for almost 2 hours thinking about the straps, Only thing I can come up with is they use the same shock for different applications and use the strap for a limit?
Neohio
Neohio
Beast of the East
13,244
63,654
Painesville Ohio
The straps keep the shocks from over extending and breaking. In turn, they also keep your CV shafts from being over extended.
These shocks are not built like yours, they will not withstand being over extended.
jmcampbell54
292
628
Texas
Exactly how I understand it.
Reactions: Neohio
207,922
Only straps I want in my S x S is my wife bra straps and I prefer her to remove them! HA!:p
207,922
Is there an advantage to this design?
Neohio
Neohio
Beast of the East
13,244
63,654
Painesville Ohio
Cheaper and easier to manufacture. less parts equals cheaper for consumer.
I believe a set of 4 is right around $1100, add in another $100 for straps and hardware.
These are not in the same league as your stage 5's.
BOX2
box3
