Side-by-Side: 2014 Honda Pioneer 700-4 Specifications
Honda News
Model:
SXS700M4
Engine Type:
675cc liquid-cooled OHV single-cylinder four-stroke
Bore and Stroke:
102.0mm x 82.6mm
Compression Ratio:
9.2:1
Induction:
Fuel Injection (PGM-FI), 40mm throttle body
Ignition:
Full-transistorized with electronic advance
Clutch:
Automatic
Transmission:
Automotive-style with hydraulic torque converter, three forward gears and Reverse. Three drive modes include 2WD, 4WD and 4WD with differential lock
Driveline:
Direct front and rear driveshafts
Suspension
Front: Independent double-wishbone; 7.9 inches travel
Rear: Independent double-wishbone; 9.1 inches travel
Brakes
Front: 200mm hydraulic disc
Rear: 170mm hydraulic disc
Tires
Front: 25 x 8-12
Rear: 25 x 10-12
Length:
114.8 inches
Width:
61.1 inches
Height:
78.3 inches
Ground Clearance:
10.3 inches
Wheelbase:
76.8 inches
Turning Radius:
14.8 feet
Towing Capacity:
1500 pounds
Payload Capacity:
1000 pounds
Fuel Capacity:
8.2 gallons, including 1.2-gallon reserve
Colors:
Red, Olive, Honda Phantom Camo
Curb Weight*:
1396 pounds
*Includes all standard equipment, required fluids and full tank of fuel—ready to ride.
Meets current CARB and EPA off-road emissions standards.
Recommended for Drivers 16 years of age and older.
