P700 Smelling burnt oil?
JeremyF
25
17
Kentucky
Anybody want to guess what the quote for a new top end is?
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
$1000, nice round number
alloutdoors
alloutdoors
1,022
2,184
US
I must admit, I’m still struggling to understand how this happened with a unit with, guessing here with around 100 hours. That is, change the oil first time at 20 ish hours so the oil change only had roughly 80-100 hours (guessing on hours but should be in that ballpark with 1200 miles). Point is, I think with Honda any oil within reasonable limits will survive a 100 hours so I will be curious what the dealer says actually failed...
swsebek
swsebek
2,854
5,828
pa
I bet it was the cam. The water story, and quick starts and stops claim are BS. They just don't want another recall. They know there is a problem with some units. Sorry this happened to you Jeremy, it affects all us 700 owners. It makes me worry for what may be no reason, but every story I hear gets me thinking it could happen to me.
Reactions: Mudwing
41,585
I'm not convinced the oil wasn't low in the 1st post.
Reactions: Mudwing
alloutdoors
alloutdoors
1,022
2,184
US
I keep thinking of my youth days on ATC, Honda XL, XR, etc., and don't recall every "really" maintaining the bike and like today, Honda's appear bullet proof. Obviously, there are variations in the engines, etc., and hopeful, Jeremy has a great dealer which can truly explain what happened and how it can be prevented going forward, because you wouldn't want to spend $XXXX dollars every "oil change"....
Reactions: swsebek and Mudwing
JeremyF
25
17
Kentucky
Guys the only thing that makes any sense to me is that I ran it too much not warmed up. Several times I jumped on late at night to run a mile down the rd where I train my dogs. It did fine going through the yard to the black top but I'd get rolling and it wouldn't shift just rev real high. I'd have to stop and let it idle a while and keep going. It was always aggravating and I wasn't patient. Did this a bunch of times last winter and this winter. Must have burnt up the rings when it revved real high. I for sure have never sunk it so don't see how water could have done anything.
41,585
Well...reving a cold engine is certainly hard on it.
The only thing is it seems from your posts that this started suddenly. Guess it could have slightly cold seized or broken a ring.
This tranny has some quirks, and the cold thing is one if them. All you can do is run synthetic and shorten the time you gotta wait and be patient. I guess you could maybe rig up some sort of block heater to help?
Reactions: Mudwing
JeremyF
25
17
Kentucky
Well I have another update...bad as it gets. Dealer is saying I need a total re-build on the motor, saying it had water in it. Guys I have never had this buggy in water deeper than a few inches in the floorboard. Didn't even know where the air intake was until I saw the buggy tore apart at the dealer today. Its higher than the seat! I've 100% never been that deep and owned it since brand new. Anybody have an explanation for what I've done here? At a loss, quote is $4,500 to re-build I need another option. I've searched the internet found one rebuilt motor for $3k might be the route I take. Anybody know of a totaled buggy with a good motor?
Mudwing
Mudwing
36,959
306,563
The Mud holes
Sorry to hear. Is the rebuild something you can handle? It’s pretty much just nuts and bolts. I’m sure the forum will help with questions.
Neohio
Neohio
Beast of the East
13,304
64,425
Painesville Ohio
Insurance an option?
Backwoods
Backwoods
31,647
325,827
Douglasville ga
Look in back of a dirt wheels mag. Lots of ads from places that part them out . Engine builders also. Could you buy a new engine . I've never priced o e.
70Bones
70Bones
888
3,779
New Brunswick Canada
I'm on a rant tonight, might was well chime in here too... First of all, not warming it up and hitting the rev limiter, when it was only 50 degrees out, will not harm any engine. Second, when an engine burns oil, it's either the rings worn or broken, or the valve seals worn out. You can find out which by watching behind you, and accelerating hard, if lots of blue smoke behind you, the rings are bad. Then get it going fast and take your foot off the gas, if there is lots of blue smoke when decelerating, the valve seals are bad. If the bottom end is gone, you should be able to hear rattling or knocking, especially when accelerating, or even idling.
It is possible that dust getting past the air filter will damage the rings and valve seals, and water ingestion can damage the bottom end (rod and crank bearings), and punch a hole in a piston. Dust and water are our greatest enemies, not running it when cold.
Russ989
Russ989
22,519
146,075
I ended up trading the 700 in to a dealership out of state for a 1000-5 LE. So glad to be out of that nightmare.
Did you have the other fixed?
Reactions: Mudwing
