P1000m5 PNW BUILD (Pioneer 1000-5)
P1000_DLux
P1000_DLux
Its Only an Opinion Relax
Belfair, WA
Sxs
Cup2
Cup1
Cup3
Bed rack silence
Center rack silence
Door silence 2
Door silence
Door Silence 3
P1000_DLux
P1000_DLux
Belfair, WA
Add the pics to help.
The cup holders are sweet and took 2 minutes to install
The sound dampening on the bed is great (Hose on the latches made it quiet)
The door dampening worked but made the doors hard to close so I removed that and replaced it with electrical tape, it is a 6 month fix and then has to be replaced again, a minor annoyance but it works really well.
It is dead quiet now and all I hear is the sweet sweet Pioneer purr!
P1000_DLux
P1000_DLux
Belfair, WA
No s***! I just bought the Translucent roof, a rocker switch panel to replace the warning plate, second battery with the isolator. Pictures to follow in the next week or two!
P1000_DLux
P1000_DLux
Belfair, WA
rb3offroad has replacement door bushing that stop the rattle in the door and we are a member of the group!!!
Okay, so I looked at these and watched a guy on youtube put them in, do they just make the door more secure and will make the rattle go away so I won't have to have electrical tape on the latch area?
208,011
They help a lot! Depends on how hard you ride! Had some guys making them out of there home shops from here, they were better than stock, but RB3 are better in my opinion. Be warned, I had two doors that I couldn't get the factory hinges to break lose from the frame with an impact, so I had to install the bushings with the hinges mounted to the frame. If you ever up grade A arms to Supper ATV, don't install the A arms until you see if the grease zerks will let you grease the A arm bushings, RB3 offload has the cure for that a well.
RB3offroad
RB3offroad
1,701
4,751
Tempe, AZ
Thank You Smitty!
RB3offroad
RB3offroad
1,701
4,751
Tempe, AZ
Yes you will be impressed! We also have a video on how to install on our website RB3 Door Bushings Video | RB3 Off Road
P1000_DLux
P1000_DLux
Belfair, WA
Okay so I might buy a set from you guys shortly, I'm also looking at the Trail Armour a-arm guards. I don't think I will swap the stock A-arms or put spacers on, we don't actually get big mud pits and stuff like that up here in Washington. I do ride decently hard "fast" when i'm out on the trails.
Papaandhistoys
Papaandhistoys
134
227
Backwoods of northern Michigan
View attachment 193075View attachment 193076View attachment 193077View attachment 193078View attachment 193079View attachment 193080View attachment 193081View attachment 193082
Added the second battery and the rocker switch panel. Lights on the way and the shaded clear roof on the way too. I also ran two battery tender quick chargers also.
Hey there friend
So, I just did my dual set up as well (from turn pro). On the tender hookup! Will charge both batteries with one hookup on the main battery or do you have to have one on each?
I hooked up to main last night and this morning the blue led was on, on the turn pro apparatus,lol. Brain fart, can’t recall the name of that thing.
Reactions: TripleB and BWAF
TripleB
TripleB
11,649
98,949
Caryville, Tennessee
Hey there friend
I hook my battery tender to the main battery and it charges both. When the isolator's blue light is on, its charging the 2nd battery.
Reactions: Papaandhistoys
