P1000 Softer Front Seat
G
graybear
118
318
East Idaho
IMG 1994
Amazon around $120
Reactions: Cal
So.. there was a significant difference in early model 17 seats vs the 16’s.. but at some point something changed and they firmed back up somewhat. I don’t know if it was the foam supplier used or what happened but I’ve sat in some that were noticeably coushier and then later models that didn’t feel much different than my 16. I even went as far as to order one last year from partzilla and it was about the same as mine.
G
graybear
118
318
East Idaho
Prior to adding the merino wool as a seat cover my 2018 seat would sometimes make might left leg fall asleep while riding. Now with the new seat cover it solved that problem.
Reactions: CumminsPusher
russknight
russknight
1,910
7,511
Perry Florida
Partzilla says the seat I purchased fits 2017, 2018, and 2019 models. I don't know if there is a different seat that is available, but I can't tell any difference in this one and the original seat in my 2016.
Reactions: clifforeilly
strongbuilt
strongbuilt
260
606
That sucks man, I was wanting to take mine in to an upholstery shop and have a new bigger pad put in with a softer cover. Maybe have it almost like memory foam..
2018GMC
2018GMC
174
356
AZ
Verdict: No discernible difference. Seat fits 2017, 2018, 2019 Pioneer 1000-3 and 5. It fits the 2016 too.
Maybe it needs some miles with your @ss in the seat to break in.
My 06/2017 build date has a fine popcorn ceiling texture on it. Were the 2016 seats completely smooth?
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
I don't think it will change much using it they shipped you a old stock 16 seat out of inventory.
Back in the day when this was first discovered I checked it out at the dealership and you could tell a difference just by pressing your thumb into it.
322,675
My 16 is definitely harder then the newer ones I’ve drove and rode in.
G
graybear
118
318
East Idaho
Where did you get that?
I ordered it from Amazon. It is a double skin that is stitched together in the middle. I had to trim a bit off each end. I then just slide it under the 2 straps on the seat. That keeps it from sliding around and can be removed for cleaning.
Reactions: Cal
russknight
russknight
1,910
7,511
Perry Florida
Anyone come up with anything to help yet?The stock seats have to be some of the most uncomfortable on the market.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
My 2016 seat was stiff and I replaced it. The new one was better. My 2018 machine has water in the seat and it's a total brick for plowing snow
russknight
russknight
1,910
7,511
Perry Florida
I ordered a 2018 seat from partzilla and could tell zero difference.
I did as well... and had the same results. Apparently they have changed something from the original 2017 updated machines. The seats in them were noticeably softer.
Reactions: Mudwing
