P1000 spare tire rack with yeti tundra 45 and rotopax mount
Moses
Moses
Owner - Brick City Fab
202
484
Gilbert arizona
Honda pioneer 1000-5 over head spare tire rack with a yeti tundra 45 cooler rack and side mount rotopax mount.
[email protected]
IMG 7636
IMG 7643
IMG 7644
IMG 7650
IMG 7651
IMG 7652
IMG 7653
Gator
Gator
The Most Unknown Member
2,489
10,470
Louisiana
That is incredible. Good work.
Will the rotopax fit between the tire and Yeti? I'm thinking it would be protected from limbs.
You really did a good job of design AND fabrication.
Reactions: Moses
Moses
Moses
202
484
Gilbert arizona
thank you I appreciate that. Unfortunately I don't believe that the rotopax cans will fit in between. The rotopax cans aver very thick so I dont seen that being an issue. i also wanted to allow for easy access to the rotopax with it being mounted on an open end.
It does look good, Can people behind the vehicle see the brake lights?
SIGNATURE:
Quote by DrFubar: joeymt33, this could be your next signature: "I should be more understanding. I should know by now that a little hill to me probably is a big hill to you.;)"
Moses
Moses
202
484
Gilbert arizona
SIGNATURE:
Thank you. It's designed to mount toward the top of the rear cage. So yes you'll be able to see tail lights no problem
Reactions: joeymt33
solrus
solrus
1,629
2,511
Montana
Moses, what pipe did you use for this mount?
Sent from my XT1585 using Tapatalk
Reactions: Moses
Manwell
Manwell
803
2,440
I really like mine, that's for sure... finally got my spare wheel and tire so its mounted on there as well.
IMG 3313
Simple to swing it out of the way if need be
IMG 3314
The dump function is no problem
IMG 3315
Plus it opens in either direction
IMG 3319
I would do it again... IMG 3317
solrus
solrus
1,629
2,511
Montana
Moses , can you fabricate 1.625" cage clamps for P500? Only 1.75" on ebay and etc. If yes, how much ?
Thank you!
Moses
Moses
202
484
Gilbert arizona
Thank you!
I use 1" wide .125 thk rubber strips to account for the tube diameter on the 500 and 700. I get clamps machined at a lot minimum of 100 so I cant afford to purchase 1.625 clamps at the moment...I dont know of anyone that offers 1.625 clamps...
solrus
solrus
1,629
2,511
Montana
Thank you! That's should work.
