P1000 Spare tire size
K9Paco
K9Paco
642
2,290
Lake Charles, La
  1. Talon X LV
I have the deluxe with the 14” rims. I bought a complete set of the 12” steel rims and I am planning on using one for a spare tire. I’ll be replacing all of my stock tires with terrabites at a 28” tire on the stock rims. What size tire do I purchase for the 12” steel rim for it to be a functional spare.
dnjones161
dnjones161
583
1,713
Ohio
28x(Desired Width)x12
outside diameter shouldnt change.
note that measured diameters, even on the same tire, may change between the 12 and 14 inch rim model, but this should be negligible for the most part. it should work as a spare.
i found the 29x11 and 29x9 tires i run, same brand, same tire, same wheel size, report different measured diameters. inflation can change it too. as long as you are within a half inch or so id say you are fine
Reactions: K9Paco
60,965
If you want to stick to same tread pattern, you'll have to go with the 27" TB since they don't make a 28 in a 12" wheel size. It would absolutely work as a functional spare. You could probably find some non-deluxe takeoffs pretty cheap on FB marketplace, but they are 26" tires(which would still be fine as a spare). You're pretty limited on the tires available in 28" that are also available in a 12" wheel.
Upload 2019 11 11 12 57 27
These are your options according to RMATV (filtered on 28" with 12" wheel size)
Upload 2019 11 11 13 1 46
Upload 2019 11 11 13 1 5
Reactions: dnjones161
