P500 Spray pump connection
T
twodog
Ozark Mountains
I sometimes use a spray tank or seed spreader on the 500. I hook up to power at the battery which is a hassle. Is there a remote connection box out there that I can attach on the back of the machine that allows easy hookup to power without getting into the battery box every time? Something weather proof but easily accessed when needed.
KYhillbilly
KYhillbilly
549
1,651
Ashland, KY
I would just use a secondary battery but yes there are numerous. A marine trolling motor plug is what i would use if wanting to have a plug or you do a simple cigarette lighter plug. Put on a longer cord and plug into cigarette lighter plug in cab.
Reactions: Mudder
Bigtee
Bigtee
556
1,213
Grayson, KY
I ordered this, just a mount for 2 prong 12 volt connector. I already have the switched hot and ground wire ran to the back, just need to install this. I plan to do some spraying with mine also. You can also make an extension using the 2 prone connector, that way you don’t have any extra wire in the back Of your SXS.
791407C7 AA95 4ABE B34D D835F1D46F91
Reactions: Bmurray
I installed a lead right out of the battery box to power my 15 gallon sprayer. You could also use your 12 volt plug on the dash. My sprayer came with three options and that was one that I used until attaching the direct lead...
CaboJim
CaboJim
87
251
53
Washougal WA
I utilized the battery tender/charger pigtail off the battery that came stock with the buggy. Plugged in right there.
Reactions: Jerryg
T
twodog
Ozark Mountains
Where is that battery tender pigtail??? Never noticed that in all my adventures with the battery box.
NTCPrezJB
NTCPrezJB
President of #NTC
105,981
943,590
Canton, OH
It isn’t factory. It could have been a dealer installed item though and the poster just didn’t know.
MtClimber500
MtClimber500
62
170
Butte, Mt
I also use the battery tender pigtail that I installed. A lot of accessories will plug into it.
Reactions: CaboJim
Mudder
Mudder
NTC Ambassador of Walls
11,602
87,332
I use the 12v plug under the dash.
