P700 Sub harness 08Z01-HL3-600
Thedirkster
Thedirkster
15
16
Ceres, Pa
Recently purchased Honda accessory sub harness 08Z01-HL3-600 for my 2017 P700-2. Guess what it DOES NOT work\fit. One could get it to work by hacking in and spicing in, but that is not the point of plug and play. The issue is that there is an incorrect connector installed on the harness that prevents you from directly plugging into the main harness. The sub harness is basically designed to be placed in between the accessory plug (cigarette lighter) and the main harness. The connection to the accessory plug is OK, but the one tying back to the main harness isn't. I spent better part of a morning at dealer (along with a dealer rep, by fortune happened to be in that day) discussing issue. Everyone agreed the harness will not work - again without hacking into harness - thus totally defeating the purpose. I was insured that the dealer and account rep would both be looking into this by contacting an engineer in California and they would be getting back to me.
So prior purchasing the harness be aware.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I'm not sure if that is the same part number that I bought.... but mine fit fine, just as intended. I have a 2017 P700-2. If you need me to look up what part number I purchased, I can do that. But it worked out great for me... your explanation of how it snaps in is correct, but the one I purchased hooked in just as it was designed..
Thedirkster
Thedirkster
15
16
Ceres, Pa
D-700 thanx for the reply....Yes, if you wouldn't mind sending me the part number that would be great. I am just wondering, though, if yours being a 700 deluxe, and mine being only a 700 - that, that might be a difference? I've attached a photo of the one I received from Honda, but doesn't not plug and play...The clear bic pen is pointing to the connector that is not compatible to anything on the main harness.
Cable harness
Reactions: bgervais
Thedirkster
Thedirkster
15
16
Ceres, Pa
OK, I guess I'm not understanding this correctly. I believe the red connector will go back to the main harness connector, correct??? What is under the blue tape on the other 4 wires? Are they all +12V, or are 3 of them +12 and then the 4th is a common ground shared between? Also are they just bare wire under the tape or do they have terminals on them?
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I was wrong...I bought the same part number that you bought...and it works fine
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
You unplug the orange (red) connector (back left corner under the hood) and you plug this in between the two plugs. It takes 15 seconds.
They all have +12V. I think one or two also have -12V (but I'm not sure).
They have terminal on them. Round terminals about 1/8" diameter.
I didn't have the mating terminal so I cut and spliced them.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I'm going to have to go out and look at mine and see how I installed it... I know it was easy..and works perfectly, as I have several things hooked to it for key on power...
tjoreo
tjoreo
1,025
1,975
Southern Idaho
I looked up the part number for a 16 and it has a different part number, so there could be some problems with the cable. I was just curious if the plugs will connect together for the harness. In theory they should because this is just a simple splice between the accessory socket if I'm thinking correctly. Sure wouldn't be the first thing honda has messed up, sorry to say.
hernjarp
Louisiana
Could anyone help with providing the correct wiring harness for a 2015 Honda Pioneer 700-4? I'm wanting to plug it in under the hood.
bigbruse
88
37
va
o bought the 08Z01-HL3-600 for my 2016 pioneer 700 and works great used it for my turn signal kit and going to use it for when i get the EZ-STEER power steering.
Reactions: GrnP500
bigbruse
88
37
va
sorry the one i got was 08Z02-HL3-A00 which to me looks identical to 08Z01-HL3-600
tjoreo
tjoreo
1,025
1,975
Southern Idaho
According to the honda power sports page it is the 08Z02-HL3-A00. There is some instructions on the install but it pertains mostly to install a back up alarm. On the last page it talks about the sub harness.
Upload 2018 1 30 12 30 51
Reactions: bigbruse
bigbruse
88
37
va
correct. it has 2 + AND 1 -
mkc809
15
11
Oakdale, LA
dirkster... did you get the 08Z08-HL5-A00 harness. Just wondering because i bought the same harness as you did and it didnt work on my 2017 700-4 deluxe. So im gonna try 08Z08-HL5-A00.
Thedirkster
Thedirkster
15
16
Ceres, Pa
The picture shows what FINALLY worked. Got it from dealer. Previous one I got was from "on-line distributor" - it was same part number - BUT different cable. Your best bet to save the grief is go through a dealer, that why if it isn't (ain't) right you go back and B out the dealer.
Dirkster
H700acc cable
mohawkhondapower
mohawkhondapower
25
11
k-town
I just bought this little switch panel and was wondering if anyone could give me a little input before I start hacking things up lol I bought this sub harness ill attatch a couple pics. I took a pic under the hood at what I think the sub harness should plug into I think. I just want to make sure I hook up all the wires right and not burn my rig down lol thanks for any help.
IMG 2710 sub FullSizeRenderpanel Bikeplug IMG 2740
Thedirkster
Thedirkster
15
16
Ceres, Pa
View attachment 67891 View attachment 67892 View attachment 67893 View attachment 67894
The connector you are pointing to with the little red arrow, is the diagnostic port. You need to tie into the accessory plug (cigarette plug).
mohawkhondapower
mohawkhondapower
25
11
k-town
ok thanks, ill look for that accessory plug again
