P700 Super cold won’t start
RandyG
15
19
I have a 2017 700-4. It is -33 with the wind chill here and the ol gir won’t start. Started last night and I plowed with it. But tonight when I put the key in the dash won’t even light up like normal. It cranks but won’t fire. It sits outside under a cover so could this be normal? Currently sitting in my 1 car garage with a heater pointed at it. But that’s the wife’s spot so can’t stay in there lol!!
Reactions: Plumber32
tjoreo
tjoreo
1,025
1,975
Southern Idaho
There's been a few with the 1000 having the same problem. My 700 was a bear to start when it was below zero. Like you, I used it for plowing and I always ran a battery tender to get it recharged but fought it when the temps dipped down. I finally upgraded the battery and that cured my starting problems. On the 1000 thread most are relating it to weak battery or gas quality issues. Maybe something in here might help.
P1000 - Pioneer 1000 regret
Sent from my SM-T350 using Tapatalk
RandyG
15
19
It cranks like normal, could it still be a battery prob? Sorry not real good with this stuff!! The dash not lighting up like normal is what really has me wondering
43,292
Try pulling relays and switching them. Or even take them inside to get warm.
Reactions: 70Bones
Diverguy
Diverguy
120
321
PA, USA
Check the 10a fuse under the hood marked "FI". I blew mine when doing some wiring and had the same symptoms...no fuel pump, no dash lights, but it would crank...just not start
Reactions: CumminsPusher
208,729
So, supposedly wind chill only has effect on exposed skin. My temp this morning was 4°, and mine started right away.
BS, pipes always freze more when the wind is up!
Deleted member 3748
Probably not that battery, but you can charge it while you check for other things.
RandyG
15
19
So the dash lights up now but my dumb a$$ left the key forward so the battery is dead now. More updates in the morning. And yes the wife’s car is still outside
Russ989
Russ989
22,642
147,257
Do you have a light bar or other electrical accessories?
Russ989
Russ989
22,642
147,257
I have a hard time believing that leaving the key on is going to kill the battery unless you have a parasitic drain somewhere.
RandyG
15
19
Only accessory is a winch, but I had tried to crank it several times so the battery could have been drained quite a bit
Russ989
Russ989
22,642
147,257
P
PolkaJoe
90
103
NEPA
Just a thought, (in some models of winches) if the winch is a wireless fob style, the receiver/relay box MAY (depending on install) always be powered up. That drain all the time may contribute to a battery issues.
322,675
That’s because it’s harder to retain heat under a house. Inanimate objects do not feel windchill. A thermometer will only tell you ambient temps
Reactions: Mudwing
