P1000 Swapping Kawasaki to Honda?
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
9BDA018D F6A6 4857 AFD5 80C6604AB2F3
8D04DB98 92F4 4CDE B1D8 F2169B8D5C0D
C43AE04F 30E5 4D93 AEE2 69AA6397FB95
EAF5659A D017 4283 BA7F 3C463296958F
I noticed they are both four lugs do you think the Kawasaki wheels will fit on the Honda?
The tires on the front appear to be identical but the back are 11 versus 12 if the rims won’t swap can I use those tires?
First 2 pics Kawasaki
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Reactions: Hondasxs
Plumber101010
Plumber101010
597
584
Sure.
If I wanted to run skinny tires all around, would the front 9.00 fit on the rear 11 rims? Assuming it would but wouldn’t balloon as far out over the rim and would be even with the edges?
208,011
What rim width you running front and rear? 9 Inch tire?
319,339
Wheels might go. Looks like if they came off of a Mule(but not pro), Tyrex or solid axle quad they will go.
Plumber101010
Plumber101010
597
584
It’s a Kawasaki Mule Pro FXT Rancher edition 2017
Sorry I didn’t think it mattered :)
Plumber101010
Plumber101010
597
584
Of course the aftermarket rims I bought for the Honda have a special socket that I can’t find now. The Lugnuts have splines in them and I can’t get them off and I’m aggravated and frustrated they can’t make rims like the other ones that just take a nut with a stud sticking out!
UGGGGGGGG
Plumber101010
Plumber101010
597
584
537213AC CF14 4F1B A0D5 3473EE188609
Crap! So won’t fit? That could be just as well because I can’t find the “Special” socket for these..
63,337
Wait.
I thought the question was can the tires be switched?
Pioneer lug pattern is 4/136.
If those wheels are 4/137 that's not the same.
Reactions: Cuoutdoors
Plumber101010
Plumber101010
597
584
So only option I have now is swapping the tires! And if I can’t get the rims off I can’t bring it up to the tire shop! Oh well, there goes a brand new set of tires I could have used :(
319,339
View attachment 144429 Crap! So won’t fit? That could be just as well because I can’t find the “Special” socket for these..
Most decent tire stores have good selection of anti theft sockets and can usually get them off. Personally I’ll use a crap socket that’s a bit too tight and hammer it on a bit. After you break it free smack socket off and remove nut by hand.
Not to bad to do on a car with one per wheel but usually atv uses all per wheel and space is more limited but it can be done.
Reactions: Plumber101010
