BOX1
Talon Talon R in Toyhauler?
Dwight
27
Kansas
Would removing the front bumper on the "R" reduce the overall length? Right now I can haul my RZR rock and trails edition + my Harley trike. It's tight but it fits. The "X" would work but I'd like to have the extra wheelbase.
Thanks
Dwight
box4
tr20pat
11
9
south mississippi
Thanks
Dwight
The X and R stock are exact same length 124"
Reactions: Remington
Dwight
27
Kansas
Well,hell! Just figured the R had to be longer because of the wheelbase. Thanks guys, I certainly appreciate the help.
Dwight
nm6r
65
123
Sandia Park, NM
Talon R
The R wheelbase is longer than the X but the overall length is the same. I know because I researched this to death before purchasing.
We shopped for a toy hauler that would fit our RZR 570 and would be light enough to tow with our Explorer. I found it does not exist so we built our own fully equipped 16 ft. toy hauler with an 11 ft. long cargo area. Our Talon R fits like a glove, even with the mattress stowed on the ceiling.
GPR1500SC
518
1,035
Memphis MO
View attachment 140413 View attachment 140414
Do you care to share some pictures of the inside of your trailer?
I just bought a Featherlite 16 foot v nose to do the same thing to be lighter weight.
nm6r
65
123
Sandia Park, NM
Talon R
I started with a locally built 16' cargo trailer with 3/4" t&g floor and nothing inside. I had the builder frame for the a/c, powered vent and windows. I took the tanks (45 gal. fresh water, 39 gal. gray, 14 gal. black) to him and explained where I wanted them. He fabricated brackets for each tank. The fresh water tank is between the axles, the gray water is just forward of that with the black tank near the front under the toilet. I also had him install the side door (with a screen door) 25" from the front to allow for the "kitchen".
I undercoated the plywood flooring with diy bed liner, painted the fenders black and added the lights as it only came with 4 on each side.
The trailer is framed with 1" square tube that I added 1/2" furring strips to so I could fit 1-1/2" poly iso insulation throughout, including the ramp. The furring strips also allow for easy attachment of the walls/ceiling panels. I also custom fit backing pieces from 2x4s for the bed frame hinges, mattress supports and tables.
The walls/ceiling are plastic sheets from Home Depot that are intended for commercial bathrooms. Sheets were bent over a 2x4 and heated with a heat gun to accommodate the front slope. I used these sheets for the shower stall too. They are very durable and are easy to clean. The trim strips are vinyl fence trim.
The water supply plumbing is PEX, the waste lines/vents are ABS and the propane plumbing is soldered copper.
Two 20 lb. propane tanks with automatic switchover valve/regulator on the tongue. The front shows a gfi ac outlet, spray port and the upper refrigerator vent. The propane furnace vents and lower refrigerator vents are not visible. On the side, leveling jacks, 30 amp ac service, spray port, water inlet (city water/water tank fill), cable, dump plumbing/valves along with Tornado tank flush inlets and a quick disconnect for a propane generator. The window on this side is also an emergency exit. On the other side is the side door with screen door, low profile mounting step and two propane quick disconnects for grill and fire pit.
View from the ramp.
View from the back, inside. Showing the A/C (heating & air), smoke detector, TV, thermostat, fold out table, gfi outlet and outlets w/usb chargers, distribution panel and in-floor battery box on the "utility wall". 6000 lb. tied downs are bolted into the floor with backing plates on the underside. "Kitchen". Screen door and fold out table on the right wall. The fold out tables are a 2' x 4' Lifetime table purchased from Home Depot which I drilled out the hinge that joined the halves, fabricated wall hinges and hung them.
Mattress suspended from the ceiling and fold down "bed frame". The flooring is Luxury Vinyl Plank. It is inexpensive, durable, waterproof and easy to install. I fabricated the trim strip on the back side of the flooring.
View from near the front. The 4" foam mattress is suspended from the ceiling. The cross straps act as a shelf allowing the mattress to be slid in/out while the center strap holds it securely in place. The center strap is the only one that gets removed. The ramp is painted (with a grit) light gray with darker gray sponged on to yield a relatively light overall color to keep the small space from feeling smaller and provide a camouflage to hide tire tracks. The "bed frames" are hinged with household hinges and held in place with a 1/4-20 knob that goes into a small piece I fabricated and attached to the trailer frame.
View from the side door. The "utility wall" on the left showing the powered fan vent control, tank monitor, Sirius satellite radio, switches for outdoor understep lights, kitchen light, bathroom lights, propane/CO monitor on the bottom. The bathroom has a small sink not visible on the left, toilet, and the 2x3 shower is on the right.
The "kitchen" showing the microwave (held in place with a couple fabricated brackets), cook top, sink, 3 cu. ft. refrigerator/freezer, propane furnace. The top left shows the tv antenna controls.
I hope this helps show what the inside is like and gives you some ideas for your build.
Ray
box4
nm6r
65
123
Sandia Park, NM
Talon R
How much was the overall cost?
The trailer cost $7k. I shopped around and could have shaved off a couple thousand but I was impressed with the construction of this one and the builder did the spare tire and carrier, framing for a/c, vent, and windows along with mounting brackets for the water tanks and propane tanks at no extra charge. More than offset the $2k.
I kept meticulous records of every purchase I made for the conversion as well as any returns due to buying the wrong part or too many. As you can see, we did not hold back and did everything we (my wife) could dream of. That said, I was very good at shopping and finding deals online. There were a few items I had to pay the price for. For example the propane quick disconnects, bulkhead and hose I purchased from a local shop but the advice and know-how that came with it was worth a small fortune. I was blown away that it cost another $9k by the time we were done. It all adds up, the A/C and refrigerator were the big ticket items. The tanks were not cheap and anything that says RV on it costs more than it should.
The bottom line was $16k to wind up with a finished toy hauler.
btw, the empty shell of a cargo trailer weighed in at 2040 lbs. and the completed toy hauler with full propane tanks but no water or SxS weighed in at 3500 lbs. We tried our best at being weight conscious knowing every pound adds up. I learned ahead of time that you cannot trust any of the builders weight figures. I know these weights are accurate because I used the CAT scales.
GPR1500SC
518
1,035
Memphis MO
View attachment 140485 View from the ramp.
View attachment 140486 View from the back, inside. Showing the A/C (heating & air), smoke detector, TV, thermostat, fold out table, gfi outlet and outlets w/usb chargers, distribution panel and in-floor battery box on the "utility wall". 6000 lb. tied downs are bolted into the floor with backing plates on the underside. "Kitchen". Screen door and fold out table on the right wall. The fold out tables are a 2' x 4' Lifetime table purchased from Home Depot which I drilled out the hinge that joined the halves, fabricated wall hinges and hung them.
View attachment 140491 View from near the front. The 4" foam mattress is suspended from the ceiling. The cross straps act as a shelf allowing the mattress to be slid in/out while the center strap holds it securely in place. The center strap is the only one that gets removed. The ramp is painted (with a grit) light gray with darker gray sponged on to yield a relatively light overall color to keep the small space from feeling smaller and provide a camouflage to hide tire tracks. The "bed frames" are hinged with household hinges and held in place with a 1/4-20 knob that goes into a small piece I fabricated and attached to the trailer frame.
Ray
I would give you triple like on your post if possible.
You did a good job on it.
That is a awesome empty weight!
nm6r
65
123
Sandia Park, NM
Talon R
Did you buy a set of plans for this or plan it out yourself?
This was my own design. I drew it out on graph paper before purchasing a trailer. Even then, all plumbing was done on the fly with a basic layout in mind. The trick was to start with all the waste plumbing since it is not very flexible (pun intended). Supply plumbing and electrical is much easier.
BOX2
box3
