Talon Tapping noise
G
Greeny
29
25
Colville Wa 99114
I have a noise behind the passenger seat at 3/4 speed in medium bumps it sounds like a metal to metal tapping noise anyone else hearing this? Any ideas. Loving my Talon!
T
The-Bearded-One
20
37
North Idaho
I hear the same thing on my driver side, like when i hit potholes. Can't figure it out either. Drives me nuts. Best i can figure is it's the crossover hitting the stop on the rear shock.
robman
robman
21
32
my rzr used to do it and it was the sway bar. slack from side to side not up and down.
G
Greeny
29
25
Colville Wa 99114
Thanks, I am going to give Honda a call to see if they have any ideas or thoughts on this noise its annoying and embarrassing when taking a friend for a ride to show off my Honda. I will let you know what I hear from them. Maybe they will be real nice after all my first Honda was a new trail 50.
Rcm936
Usa
Is it on sharp edge bumps? Sound like a hammer tapping the frame? If so check the nitrogen in your shocks.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Hitting the crossovers on the shock will make some noise. I saw something on FB where they thought there wheel bearings were already shot and it was just the radius rod bushing play.
Reactions: Plumber32
G
Greeny
29
25
Colville Wa 99114
Rcm936 described it well it sounds like a hammer tapping the frame. Keep the ideas coming I plan to check them all out this weekend. Thank You
G
Greeny
29
25
Colville Wa 99114
I hear the same thing on my driver side, like when I hit potholes. Can't figure it out either. Drives me nuts. Best I can figure is it's the crossover hitting the stop on the rear shock.
Bearded one have you found your noise yet? Mine is making me insane I am asking every Honda owner I see and have had no luck.But have met some very nice people! Honda referred me back to the dealer who had sold 3 so he has
G
Greeny
29
25
Colville Wa 99114
Bearded one have you found your noise yet? Mine is making me insane I am asking every Honda owner I see and have had no luck.But have met some very nice people! Honda referred me back to the dealer who had sold 3 so he has no ideas.
hondabob
1,281
5,088
Prescott Valley, AZ
Its the cross over rings. Move them up and it helps the low speed washboard ride. Make sure it will cross over to the main spring before the tender spring coil binds.
Reactions: TripleB
G
Greeny
29
25
Colville Wa 99114
Thank you hondabob I have a friend that can help me with that. I’ll let you know how it goes. Thanks again!
CincyCuda68
59
37
Ohio
Mine went away after filling the low N2 in the shocks.
CincyCuda68
59
37
Ohio
Thank you! Did Honda help you out with the filling or did you do it on your own?
I did it myself, I rarely use a dealer unless it’s warranty work. No offense Honda Tech!
G
Greeny
29
25
Colville Wa 99114
N2 was good had them adjust the crossover springs as hondabob recommended noise is gone! Thanks everyone for the input. Special thanks to hondabob on this one.
Reactions: TripleB
