BOX1
P1000m5 Rock Donkey v2 Long Travel
6b89bb20d83c581e9269987f343d6f94
Picked me up one of these high dollar foam widgets y'all all talk about. I hope I didn't waste $8.95 on nothin'!
I got one of those recently - it does a good job with the foam still looking for the right solution to use for the wash
Gonna try simple green in the morning. Gotta clean mower and do some maintenance and I'm gonna clean Pioneer before I do some adds and maintence.
I've got some "crud cutter" I picked up when I bought pressure washer.
It's not eco friendly like simple green.
Reactions: Ragnar406
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,150
Cullman, AL
  2. Other Brand
The purple krudkutter works pretty good on painted and aluminum parts and safe for them. 100% concentration. Other color krudkutters didn't work very well. Where did u get the foamer?
Ragnar406
Ragnar406
The Great Bald One
4,443
17,010
Bella Vista, AR
I usually do a mixture of a cup of tide and a cup of degreaser to 1gal of water that I spray on with a sprayer. When we first got the foam cannon my wife used that mix in it on her car and said her car never looked better - I think the mix has to be different as it picks up water getting sprayed. Let me know how simple green works I bought some of that to try - know if I add a splash of dawn the suds will come
Awesome the krudkutter has just been sitting in a jug. the foam nozzle on my pressure washer is crap.
Amazon, someone had returned it and it was 8.95 warehouse deal. I'm cheap and will sometimes wait until I can get a warehouse deal or slightly used on from Prime.
Fasmov Car Wash Pressure Washer Jet Wash 1/4" Quick Release Adjustable Snow Foam Lance Foam Cannon Foam Blaster Amazon.com: Fasmov Car Wash Pressure Washer Jet Wash 1/4" Quick Release Adjustable Snow Foam Lance Foam Cannon Foam Blaster: Automotive
Reactions: snuffnwhisky
39,078
I use this one with Super Clean. I set it to 10:1 and it works really good. I used to mix super clean 2:1 in a pump sprayer but you used a lot of product. I guess because it foams it works better even though it's 10:1.
7279c0ab206e8db300cef1c271c6b09f
E
elkguide
3,377
7,963
Vermont
Either you don't get that thing very dirty or that foamer really works!
Reactions: joeymt33
It gets dirty, I'd rinsed it off to put the a-arms on, and then out rode through a downpour on the interstate, so it was mainly, chunks where it was hard to get to and mud film.
I normally have to scrub it by hand to get the mud film off, the Simple Green foam lets me just pressure wash it off, works way better than spraying it on with a weed sprayer. Took maybe 35 mins(15 of that I was doing something else) to do whats normally an hour or better of smearing mud all over it.
I'm gonna adjust the valves and I'd rather work on a clean machine if I'm gonna open the motor up.
Reactions: joeymt33 and allgm1
I have plans to make mine street legal so I picked up a TurnPro Deluxe kit.
It has the Horn and the Trailer Pigtail included.
The instructions are pretty clear, a little more detail on mounting and splicing locations could be provided for the rear lights(I should have taken a before shot of where I spliced into the rear lights but all I have is an after).
Otherwise I really like the kit.
For this I will be using this portion of the kit.
Ec07df5dda1bfaff28cddcc38c75d948 jpg
This thing sounds really good far better than the generic AutoZone horn I already had and was going to replace
9e63ab48f9d644369ae536864e8b1783 jpg
The included horn button, add-a-circuit, and turn signal switch included with the kit will be set aside since I already had a lighted horn button, lighted DPDT switch from OTRATTW(to give me a dash signal indicator), and a circuit on my PDM60 that I was already using for the crappy horn I had installed.
C2148fc627bd552c8959e3f1eed7f3d7 jpg
I started by finding locations for switches by the steering wheel.
Be warned the location on the right side will really only be good for a single switch as the gauge cluster sticks out under where I cut my hole. Luckily the upper switch in the picture with no rocker is going to be used for a purpose where I only needed the switched contacts and not the ground or led contacts, so I was able to cut them off and grind them down to make it fit.
If you're going to put two switches on one side the left side would be best.
2e9fd0dd4593ea756c98bee0a722c7fb jpg
Ca64f3cdb0bb152bd3fa1adf97e77663 jpg
If you install rockers where I did I advise against using a plastic switch slot, the dash is curved enough it doesn't quite sit flush but it's too late for me.
Instead install them separately like I have the turn signal switch.
I am going to add a Hazard switch directly below it and wire in the TurnPro harness with the diodes.
A5ab9e2a2ee43047bd017d88b0f95deb jpg
Next I installed the front lights, a ¾" wood paddle bit is perfect. I measured them so they would be sitting evenly spaced and centered. Drilled the holes and pushed the grommets in then the lights.
385b6a5e529ce084674ea50589c60175 jpg
I placed on high and on the side of the a pillar just because three wouldn't fit on the fender flare.
3d3ebabb37d824b0a4a2e2022e166afa jpg
I think I will order (6) more similar lights and splice them in since the Honda Accessory bumper makes it hard to see from all angles.
I'll place them on the outer edge of the factory head lights.
061f60305ddc776cd218d8ea29f6b113 jpg
This location is perfect due to being able to run the wiring harness between the inner fenderwell and the fender. It protects it front limbs and sticks and other things trying to rip it out.
With that out of the way I moved onto the horn.
The only space I had left under the hood was here. So I bent the bracket to lift it up and over the factory relays.
516e1814ac7f3e3d6b38ace6d8205643 jpg
I ran the TurnPro harness along the crossbar and down into the space between the fenders. The sides are labeled so it's fairly difficult to screw up and get them backwards but also not a big deal if you do. Since it's easy to re-run the wires.
The White Wire on the TurnPro harness is GROUND.
Red is Positive from battery, So anywhere along the harness you can splice into these wherever is convenient to get power.
Since my PDM60 is mounted to the passenger side of the under hood area I placed the flasher relay under the dash along with the extra wire from the front turn signal portion of the harness.
Then spliced into the TurnPro harness and got power and ground to my PDM60 and ground point under the hood.
I was able to use the same splice to get power/ground to the flasher, my turn and my horn switches.
I then connected the green and yellow wires to the turn switch and fed the positive output to the horn from its switch.
Using the supplied switches is even easier they plug right into the harness you just have to find a place to mount them that you're happy with and can reach.
The power feed in the middle of the harness for the 700 I cut off and taped the ends. As I didn't need it where it was.
Now to the dirty part.
Drop your skid plate, cause you've got to run the wires along the inside of the Drivers side of the lower framerail. Then up the upright just to the rear of the engine and DCT filters, this will bring it right to the rear light harness.
This is where I should have taken a before shot. Oops.
765f974859ba7c989a374d7559f0ecb0 jpg
With the ignition off and battery disconnected cut the factory harness about the middle of where I have the converter mounted. It's 6 wires in a ¼" wire loom running right where I have the Converter mounted.
(2) BROWN-TailLights
(2) GREEN- Ground
(2) GREEN/YELLOW - Brake Lights
Then you have the TurnPro Harness you just ran back there.
White-Ground
Green-Right Turn
Yellow-Left Turn
Follow the rear portion of the harness back to a point under and in front of the tailgate to a connector. Disconnect the connector and pull that portion you cut loose away from the machine.
Again another before shot would've been helpful. You can just see the factory connector to the right of the left pivot point of the bed.
E127bffe30f92396affc512988403930 jpg
On the cut end strip and twist the two green wire together and do the same with the two brown wires.
Next it's helpful to have a 12v DC power source whether it's a spare battery or a 120 to 12v power supply.
I used a spare battery I have just for this purpose along with some alligator clips.
Take the pigtail and plug it back into the harness, while you're at the rear of the machine. Connect the GREEN to the negative side of your power source and then pick one of the green/yellow wires from the rear portion of factory harness. Very conveniently one runs the left brake light and one runs the right one. Note which side lights up for the one you picked.
Take the converter, the rear portion of the harness and the trailer pigtail (if included in your kit) over to a work bench. You can make all of these connections there much easier.
Connect the "trailer" side of the converter to the rear portion of the harness( and trailer pigtail)
Converter----Harness[Pigtail]
White-----Green [White]
Brown----Brown[Brown]
Yellow----Grn/Yel for left Brake[Yellow]
Green----Grn/Yel for right Brake[Green]
Once you've made all these connections, you can take this new harness with the converter back to the machine and rerun it the factory route back to the connector under and in front of the tailgate.
Clean the plastic with rubbing alcohol and stick the converter in place.
Here's the last bit.
To the Vehicle/Car side of the converter
Converter----Factory Harness[TurnProHarness]
White-----Both Green[White from TurnPro Harness]
Brown----(1) of the two Brown
Yellow----[Yellow from TurnPro Harness]
Green----[Green from TurnPro Harness]
Red------(1) of the two Green/Yellow
Reconnect the battery, turn key on and check the operation.
Last step find a cold beverage and enjoy your handy work.
B86034a270b938392166d15628ea262a jpg
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,150
Cullman, AL
  2. Other Brand
Street legal for Bama ?????
Reactions: joeymt33
I have spoken with the Shelby County Sheriff about using out of state tag. He said as long as it meets requirements for a vehicle in AL and the state it's tagged in. He's good with it, if anyone has an issue he gave me his business card to have them call him direct.
AL has NO law saying you can't use it on street just a law requiring a Title to get a tag from AL to finish your street legal requirements.
Tag
Rear view mirror
Windshield wiper
Be able to attain speed limit for road you're on.
Since a vehicle tagged in another state can be driven in AL, he sees no problem with it. He said ONLY issue a LEO might can get me on is helmet law, but it'd be hard sell since it has 4wheels and in AL less than 4 is a motorcycle.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,150
Cullman, AL
  2. Other Brand
Tag
Rear view mirror
Windshield wiper
Wow going to have to check in on this.
Reactions: ohanacreek
Lol, as some folks around here would say for a go getter, that damn snuff will do something
Ok so I have two choices:
one buy enough land in TN to place a mailbox on it, and have two bills sent there. Then I can get a Class 1 tag.
or
two call every county in SD and see which one will let you register remotely, SD DOR says it's up to the county for remote yearly registration.
What TN resident will sell
Me 4 sqft of land for a reasonable price?
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,150
Cullman, AL
  2. Other Brand
or
I'll go in half for 2 sqft ;)
Similar threads
BOX2
box3
