I’m wanting to buy bigger tires for my P500. Please help on tires size as I’m up in the air as to 26” or 27 “ as I want to stay with 12” wheels I think. Pros & Cons !!! Please way in with your suggestions !!! Thanx in advance !!!
Those are some gripping tires, if they made them in 8 ply I’d put them on my P1K5D!
I'm running ITP Blackwater Evo 26x9-12 all around on STI HD Beadlock wheels 5+2 with no spacers. I went with 26" to be sure the P5 would fit inside my enclosed trailer. Since the blackwaters are slightly undersized, I think I can go with 27's when these wear out
26" Evo next to 25" OEM
To avoid confusion, I probably shouldn't have abbreviated Evolution to Evo.Anyone with a P5 running Blackwater's?
You could probably run those with no air in them!I'm running 25" GBC Kanati Mongrel 10 ply DOT rated radial tires, awesome tires. If I ever need a new set, I'll go with 26" next time. These are tough, gripping, smooth running tires off road and on road.
I am running SunF 27’s (9”wide fronts, 11” wide rears) on stock wheels and tires with 1.5” spacers all the way around. Definitely recommend spacers if your going to a 27.I’m wanting to buy bigger tires for my P500. Please help on tires size as I’m up in the air as to 26” or 27 “ as I want to stay with 12” wheels I think. Pros & Cons !!! Please way in with your suggestions !!! Thanx in advance !!!
