P700 Tire wear
Booey424
Booey424
53
New Haven, WV
I have just under 1000 miles on my 700-4 deluxe. The front tires already need replaced. Especially the passenger side. It’s almost bald alreadY
I ride mostly on pavement or gravel roads. Not too much mudding. I’m looking for a front tires that will last longer. Are radial tires better?
Also the tires are 25x8x12.Can I get tires a little bigger with the stock rims?
JimmyA
JimmyA
1,644
5,503
Northeast texas
I am running "Tusk Terrabites" from Rocky Mountain and they are great tires for your application. Mine are 27/9/12 on stock wheels, I highly recommend them as a All Terrain tire!
Reactions: Backwoods
tonyc
tonyc
26
34
I am in a similar situation. Do alot of rough asphalt road driving with sandy trails. Stock ones are wearing down very fast! Will these tires do well in the sand also? Are you happy with the same size tires on all 4 corners?
JimmyA
JimmyA
1,644
5,503
Northeast texas
I am very happy running the same on all 4 corners! I haven't ran in any sand here.
Reactions: tonyc and Backwoods
Mopower58
Mopower58
No reservations about no reservations
69,554
639,826
Crystal Springs,Ms.
Double check your toe in. A lot of the P1K's were towed out from the factory and that will cause excessive front tire wear.
41,642
So now looking at the GBC kanati mongrel for a radial with good tread wear and mud capabilities. Any thoughts?
Just to be clear, I have no ideal how they do in mud. I was just doing a smartass wordplay on the name. Most of that type of tire with closely spaced tread blocks probably won't be real impressive in mud.
Mopower58
Mopower58
69,554
639,826
Crystal Springs,Ms.
Regular Bighorns or Bighorn 2.0?
Mine are Bighorn 2.0, 9's and 11's.
IMG 0925
Backwoods
Backwoods
31,859
327,815
Douglasville ga
Bighorns do pretty decent in muddy conditions and the ride quality is very good I am going back to them very soon. My mud tires are good but with a little wear the ride is annoying. I have had them before they are going to be a welcome change.
Reactions: Mopower58
DBD
DBD
67
141
Pennsylvania
I have a p700-4 with 2" super atv lift. Getting into Blackwater Evo radials on stock rims. Can I run 28×10×12 all around or 28x9x12 around?
Backwoods
Backwoods
31,859
327,815
Douglasville ga
They should only come in 10 wide on 28s . You can but you might want to put a 1inch spacer on all 4 to widen for stability.
