STI out back. Theres two versions mine are the light ones they have been good and grip well in everything including rock. They ride good except on asphalt under 6_7 mph and their fine on anything elseBackwoods what kind of tire do you run?
You cant make them rub there's plenty of room.So the 27s shouldn't rub . I don't want a lift on it.
Dang that looks like 28s would fit.You cant make them rub there's plenty of room.View attachment 189833View attachment 189834
Dang that looks like 28s would fitYou cant make them rub there's plenty of room.View attachment 189833View attachment 189834
I'm looking at 27 inch zillas or can anyone recommend a better tire. Nothing that's gonna ride ruff I use it for hunting and a little mudding if need be.
I'm between the zillas or the interforce. I want the interforce the same size all the way around. 27_7 may as well say 8_12 which do you think would be better and what's your opinion on running the same size interforce all the way around?I'm putting 27" interco interforce tires on mine. I used to run them on my Suzuki King quad, they're pretty light and get really good traction and roll smooth
what size interforce do you run and which ones ? I'm wanting to run just the interco. Not interco 2. And I'm wanting to run the same size on front and back which is 27 x8x12 they weigh 25 pounds apiece . You don't think the pioneer will pull them? My next choice are the zillas.they weigh 21pounds eachI don't know if I would do the 10s up front. I feel like the steering would be way too heavy with that much tire. The interforces move a lot of dirt, Im almost thinking about taking them back off because you can barely spin all 4 in deep mud. Because the pioneer is just way too underpowered
I have the regular interforces. 27x7.5 up front and 27x10 on the back. I guess you could run 27x7.5 all the way around but you probably have to change the rear rims to something a little more narrowwhat size interforce do you run and which ones ? I'm wanting to run just the interco. Not interco 2. And I'm wanting to run the same size on front and back which is 27 x8x12 they weigh 25 pounds apiece . You don't think the pioneer will pull them? My next choice are the zillas.they weigh 21pounds each
