P700 Tires. I need some advise
CWL23
69
46
Louisiana
I'm looking at 27 inch zillas or can anyone recommend a better tire. Nothing that's gonna ride ruff I use it for hunting and a little mudding if need be.
Reactions: Isaiah
Backwoods
Backwoods
31,785
327,079
Douglasville ga
I run 27s on my 700
Mine are light and I have no power loss or regrets , whatever you choose just be weight conscious and you will be happy . The GBC dirt commanders have been recommended to me and they are under 30lbs apiece. Bighorn 2.0 is a light smooth riding tire.and there are many others.
Reactions: Isaiah and Mudwing
Backwoods
Backwoods
31,785
327,079
Douglasville ga
I think most mud tires can be a little bumpy at low speed. I know mine are but only on pavement.
Backwoods
Backwoods
31,785
327,079
Douglasville ga
Backwoods what kind of tire do you run?
STI out back. Theres two versions mine are the light ones they have been good and grip well in everything including rock. They ride good except on asphalt under 6_7 mph and their fine on anything else
20200313 202006
Backwoods
Backwoods
31,785
327,079
Douglasville ga
They say some will some won't on the 28s it just depends on how true to size they are.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Tire width has alot to do with it also. Which also effects the ride. I could scrub my executioner 27x10s up front with a 2.5 lift but that was at full lock and in a nylon bind. I think the 5 yrs i had them on i scrubbed like 4 times.
TX_duckhunter
12
Texas
If you want the zillas weight and tread, go with the CST wild thangs. Same parent company, but the wild thangs are a UTV rated tire. Check the weight limit on zillas you'll be over them pretty easily. Pletny of guys runs them, but its the same tire just rated correctly so what's the harm right?
CWL23
69
46
Louisiana
I'm between 27inch zillas . Or 27 interco interforce. The interforce are gonna be the same size all the way around. 27_8_12 what's your opinion on the tires.?
CWL23
69
46
Louisiana
I'm putting 27" interco interforce tires on mine. I used to run them on my Suzuki King quad, they're pretty light and get really good traction and roll smooth
I'm between the zillas or the interforce. I want the interforce the same size all the way around. 27_7 may as well say 8_12 which do you think would be better and what's your opinion on running the same size interforce all the way around?
Bigseff23
97
171
Lakeland Florida
I don't know if I would do the 10s up front. I feel like the steering would be way too heavy with that much tire. The interforces move a lot of dirt, Im almost thinking about taking them back off because you can barely spin all 4 in deep mud. Because the pioneer is just way too underpowered
Reactions: Backwoods
CWL23
69
46
Louisiana
what size interforce do you run and which ones ? I'm wanting to run just the interco. Not interco 2. And I'm wanting to run the same size on front and back which is 27 x8x12 they weigh 25 pounds apiece . You don't think the pioneer will pull them? My next choice are the zillas.they weigh 21pounds each
Bigseff23
97
171
Lakeland Florida
I have the regular interforces. 27x7.5 up front and 27x10 on the back. I guess you could run 27x7.5 all the way around but you probably have to change the rear rims to something a little more narrow
