P1000 Torque specs
pct
pct
Lost in the hills
790
1,023
Letart WV
Where can I find the torque specs for the a-arms and the front bearing nut need to know putting on my a-arms and need to find them
Thanks,Paul
Thanks,Paul
I can get them when I get home in several hours.
Signature:
QUOTE by Tflynn, "The aftermarket doesn't build what you want? Show them your favorite finger and build it yourself!"
pct
pct
Lost in the hills
790
1,023
Letart WV
Thanks for the info
Paul
BrophyCreek
BrophyCreek
496
3,061
New Richmond, WI
top a arm 32 ft lbs bottom a arm 47 ft lbs, upper ball joint 21 ft lbs, lower ball joint 36 ft lbs , wheel hub nuts 101 ft lbs
Thank you for posting this I'm headed to the Pioneer take over have to install a arms today when I get there and I was the one thing I did not know. Well that in the hub nut size I saw somewhere else it's 30 mm. But thank you I was able to do a Google Search and found this!
