P1000 Tough Country Bumper Install
TripleB
TripleB
15,686
140,698
Caryville, Tennessee
Installing a winch on this bumper has been somewhat of a chore. I purchased the 6000# Viper Elite Widespool winch from the club store. The mounting slots are quite a bit larger in diameter than the winch mounting bolts, especially the smaller two. I had to fab up some spacers to fit inside the slots in order to keep the winch bolts centered in the slots. Thick washers must be used on the underside in order to keep washers from deforming into the slot when tightening the winch bolts. It's kind of been a pain....
There was a mounting plate for the winch that goes there. I have the 4500lb viper from the club store on my 3 seater.
20210521 205958
20210521 210037
20210228 110419
Reactions: Lady01 and BigOL3
05Willys
05Willys
529
3,323
PA
That's why I plan on fabbing a plate to use under the top bumper plate. I'm hoping this will be the easiest way to deal with the slots.
russknight
russknight
1,910
7,511
Perry Florida
There was a mounting plate for the winch that goes there. I have the 4500lb viper from the club store on my 3 seater.View attachment 273110View attachment 273111View attachment 273112
Correct, and I am using the plate. That isn't the issue. The slots in the bumper are wider than the bolt diameter of the winch which leaves room for the winch to move around even with the bolts tight when in a heavy winching situation. Poor design, IMO, but I shall overcome.
Reactions: Lady01 and TripleB
russknight
russknight
1,910
7,511
Perry Florida
That will help if you fab some kind of spacers that the bolts go through that fit up into the slots.
Reactions: Lady01
05Willys
05Willys
529
3,323
PA
Just fab the plate to fit up tight to the pipe in the bumper then it won't move no matter how hard you pull.
dukeANhammer
dukeANhammer
60
147
I also had a time with the bolts to mount the winch. I ended up taking the mounting bolts to ace and buying the longer ones and a large and small washer for each bolt. I only had the bottom 2 bolts in the bumper,so it would swing down and i could mount the winch.
F07E47C8 6623 4B27 B924 5AFA92912A19 E1CC27E6 4C4E 4241 8543 BB6A2361C731
russknight
russknight
1,910
7,511
Perry Florida
View attachment 273415 View attachment 273416
Good looking machine! The problem I ran into was the stock bolts were too short on the motor side. The longer bolts were about 1/4" too long (didn't realize it until too late). For reference, I used heavy flat washers to compensate for the bolts being too long after the fact. Not sure why only one of the motor side mounting points busted. The bolts were the same length. I also left the bottom two bolts in and used a floor jack with a piece of pipe under the receiver to hold it in place while doing the install.
Swampmonkey
Swampmonkey
149
149
Al
Have you notices any sagging in front from additional weight or steering issues? Bolt holes for winch may turn me off to this bumper. How many inches does it stick out from grill?
Reactions: Lady01
dukeANhammer
dukeANhammer
60
147
I haven’t noticed anything any different, no sagging or steering issues. Think the bumper weighs 72lbs plus winch
dukeANhammer
dukeANhammer
60
147
So approx 6” from the very front plastic? Have you done any winching yet?
Not anything major yet, they’re metric 10.9 bolts with grade 8 washers staggered in size to keep the bolt heads from pulling through the washers. Imo the bolts would break before the heads pull through those washers.
B9455FAD 88F6 4A72 BD55 82E3519719A2 5F6FFF0E 7648 4A32 B914 B4EF41C8AE4A
BigOL3
BigOL3
2,994
8,920
I have found the extra weight on the front to be a PLUS when making steep climbs ...... helps keep the front down.
Swampmonkey
Swampmonkey
149
149
Al
Did anyone look at the slasher while researching bumpers? If so what moved you towards tough country?
Reactions: Lady01
