• Welcome to HONDASXS.com
    If you are a guest please take time to REGISTER with us. Stay up to date on the Honda Side by Side line and take part in our online forum. Check out the FAQ. Once you register you can start to make post. Users will respond to your question or statement. To start viewing messages, select the forum that you want to visit below or click the board index to see a list of all forums. Thanks and have fun.
P500 Turf mode manual locking hub
Discussion in 'General Pioneer 500 Discussion' started by Chooglin, Jul 16, 2019.
  1. Chooglin
    Chooglin Well-Known Member
    Vendor Lifetime Member Club Contributor
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
  2. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Found what I needed........entire assembly, knuckle and hub on ebay $50. A member has an axle for me , so I am good to go!!!
    rtn001 likes this.
  3. trigger
    trigger Old Ironsides
    Vendor Lifetime Member Supporting Member
    5,567
    15,164
    Ownership:
    500
    rtn001 and Chooglin like this.
  4. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    I hope to install a locking hub on the rear so we can all have turf mode. The next step is to find a locking hub that will fit the splines on the axle. Anyone that wants to help me research this , please do.
    This is going to require a little machine work but I think its doable!
    Eltobgi, trigger and rtn001 like this.
  5. Cyberjunk
    Cyberjunk Berserker
    May 10, 2017
    1,158
    2,799
    Crane Hill Alabama
    Ownership:
    700-4
    Looked into this awhile back there was a model of Kawasaki that had a hub in one side you could unlock . Was a mid 80s model
    trigger, rtn001 and Chooglin like this.
  6. Cyberjunk
    Cyberjunk Berserker
    May 10, 2017
    1,158
    2,799
    Crane Hill Alabama
    Ownership:
    700-4
    Need to find this hub
    Chooglin likes this.
  7. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    This is pretty much what my plan is , but the locking hub splines need to match the axle spines from the Pioneer. I also need to find a locking hub that is readily available, I doubt you could even find one of the Kawasaki hubs they used on this 3 wheeler.
    Adapting the locking hub to the pioneer "should be" easy , finding the proper locking hub with the same splines ,not so easy!
    #7 Chooglin, Jul 16, 2019
    Tjd and rtn001 like this.
  8. trigger
    5,567
    15,164
    Ownership:
    500
  9. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    I do to , it would just be nice to unlock it while cruising around the yard!!!
    Arizona, rtn001 and trigger like this.
  10. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Does anyone know what the spline count is on the axles ? Until my parts are delivered, I don't have a clue. It seems like someone had mentioned they are 30 or 31 ?
    rtn001 likes this.
  11. DG Rider
    DG Rider Well-Known Member
    4,236
    13,288
    Ownership:
    500
    I think you're going to find that this works when turning away from the driving wheel, but turning into it is probably going to dig up whatever as bad as the spooled rear end. Not to mention the handling problems.
  12. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Possibly, but I know my tractor doesn't tear up my lawn, there is only one wheel driving the rear unless I lock the other wheel in!!!
    Arizona, Eltobgi and rtn001 like this.
  13. Montecresto
    Montecresto Montecresto el segundo
    13,675
    20,333
    Ownership:
    500, 1000-3, 1000-5
    rtn001, Mudwing and Chooglin like this.
  14. Montecresto
    13,675
    20,333
    Ownership:
    500, 1000-3, 1000-5
    rtn001, Eltobgi, Mudwing and 2 others like this.
  15. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    I just ordered a locking hub yesterday that I think will work. Its being shipped from California, so it will take a few days to get here. I also ended up ordering a new rear axle yesterday, I figured rather than get a used one , it would be nice to have a extra new one just in case!!!
  16. Bastardchild
    Bastardchild Well-Known Member
    Nov 3, 2016
    1,329
    3,996
    Orange Heights, fl
    Ownership:
    500, 700-4
    Never heard of unlocking a hub on a sxs, much less a 3 wheeler. I gotta follow this thread. Interesting idea.
  17. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    I just hope I can make it work. After looking everything over , looks like a custom axle may need to be made. The splines on the wheel hub end , are not long enough......... I need about 1.00" more of spline!!!
  18. Bastardchild
    Nov 3, 2016
    1,329
    3,996
    Orange Heights, fl
    Ownership:
    500, 700-4
    I can see where attempting this on a vehicle with a solid rear axle would probably be way easier than on an IRS vehicle. Not a lot of room to work with. I look forward to watching this.
  19. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    I received the axle and manual locking hub and I'm happy to say , the locking hub splines match the axle splines perfectly. Now I need to figure out how I'm going to mate the locking hub to the wheel hub. I will keep you all updated on this as I get further in to it.
    The locking hub is from a Kia sportage!!!!
  20. Montecresto
    13,675
    20,333
    Ownership:
    500, 1000-3, 1000-5
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
    Dismiss Notice
Loading...
