• Welcome to HONDASXS.com
    If you are a guest please take time to REGISTER with us. Stay up to date on the Honda Side by Side line and take part in our online forum. Check out the FAQ. Once you register you can start to make post. Users will respond to your question or statement. To start viewing messages, select the forum that you want to visit below or click the board index to see a list of all forums. Thanks and have fun.
P500 Turf mode manual locking hub
Discussion in 'General Pioneer 500 Discussion' started by Chooglin, Jul 16, 2019.
  1. Chooglin
    Chooglin Well-Known Member
    Vendor Lifetime Member Club Contributor
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    Lmao..........who would do such a thing ;)
    monaco and trigger like this.
  2. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    Funny chit
  3. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    Started machining the spindle for the new wheel hub and locking hub. I ran into a miner problem and needed to order a new double row, double sealed bearing, so I am waiting for delivery on that before I can continue.
    After I get the spindle finished , i will start machining the new wheel hub. I am machining all of the parts from aluminum just for the prototype because its easier/faster to machine. All of the final parts will be machined from 4140 prehard heat treated steel.
    There will be some changes to the spindle that you see in the pics, but this is pretty much what it will look like!!
  4. Cyberjunk
    Cyberjunk Berserker
    May 10, 2017
    1,156
    2,787
    Crane Hill Alabama
    Ownership:
    700-4
    Went ahead and just made mine turf mode the quick way . c5742c5a2faa4de81005c22126960341.jpg 571a67dd00418f3fb6d40dc93908a3bd.jpg
  5. Mudder
    Mudder Patriot Rider
    Oct 1, 2016
    3,206
    10,956
    Ownership:
    500
    Just add a locker and you’re back to 3 wheel drive!
    CumminsPusher and Chooglin like this.
  6. lee
    lee Incompetents at work here
    Apr 4, 2013
    1,138
    5,323
    Springfield Ohio
    @Choog what is the offset on your wheel?
    Is that hub going to make you wider than 50” (or 75")?
    Waiting to see how this turns out.
  7. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
  8. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    Lol..........I could add a locking hub to both rear wheels and have two wheel drive too!
    Bastardchild and Mudder like this.
  9. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    I have 5+2 wheels. The plan is to make the spindle so that it ends up being 1 1/2" wider on the side with the locking hub...........it will be the same as adding a 1 1/2" spacer to one side. I will remove the spacer that I have on that side and just run a 1 1/2" spacer on the opposite side!
  10. Cyberjunk
    Cyberjunk Berserker
    May 10, 2017
    1,156
    2,787
    Crane Hill Alabama
    Ownership:
    700-4
    Climbing a rocky hill wheel hopped up spinning and came down hard .
  11. lee
    Apr 4, 2013
    1,138
    5,323
    Springfield Ohio
    Sounds easier than what Choog is doing...
  12. Cyberjunk
    Cyberjunk Berserker
    May 10, 2017
    1,156
    2,787
    Crane Hill Alabama
    Ownership:
    700-4
    Ok folks found a problem with just one wheel pulling , instead of a unlocked differently . As I had broke the splines out of my drivers side outer joint I had to remove the axle and had a broke stab axle to replace it to get my garbage to the road ( Monday AM early they pickup ) . Gravel road at the bottom of my drive and cement drive with a good grade. I could not get off the gravel without spinning the right rear tire to the point put it in 4x4 to get backup on the cement . After getting on the cement I had to feather the gas to keep from spinning . Granted this isn’t a real big deal and I have a great turning radius now and when I was driving around the yard it was great except any grade and you will be spinning.
    trigger, Mudwing, Gassygordo and 2 others like this.
  13. JeremieBaker
    JeremieBaker President of #NTC
    Jan 30, 2018
    10,744
    45,216
    Canton, OH
    Ownership:
    500
    Bahahaha.
  14. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    I honestly don't know how this thing is going to affect steering ,turning radius, traction......etc. If it causes issues , I can always go back to the stock setup. It's definitely going to be different, I just don't know "how different"!
  15. Mudder
    Oct 1, 2016
    3,206
    10,956
    Ownership:
    500
    With loss of rear traction issue, seems like running in 4wd full time would be necessary.
    Chooglin likes this.
  16. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    My yard is pretty flat , so I think I should be ok.
    Also the one wheel braking in the rear could be a little funky!!!
  17. Bastardchild
    Bastardchild Well-Known Member
    Nov 3, 2016
    1,328
    3,991
    Orange Heights, fl
    Ownership:
    500, 700-4
    Such ingenuity
    trigger, Mudwing and Chooglin like this.
  18. CumminsPusher
    CumminsPusher The woods made me do it,yet again!
    Lifetime Member Supporting Member Club Contributor
    21,262
    88,057
    Ownership:
    1000-5, Other Brand
    Seg, Bastardchild, trigger and 3 others like this.
  19. Chooglin
    Dec 2, 2014
    3,682
    10,610
    Mantua ,Ohio
    Ownership:
    500
    Lol......the locker was a necessity and the locking hub is one of those things where I just need to know if it can be done :). I do think this will be a nice feature, as long as it can handle the abuse when locked!
  20. CumminsPusher
    21,262
    88,057
    Ownership:
    1000-5, Other Brand
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
    Dismiss Notice
Loading...
