• Welcome to HONDASXS.com
    If you are a guest please take time to REGISTER with us. Stay up to date on the Honda Side by Side line and take part in our online forum. Check out the FAQ. Once you register you can start to make post. Users will respond to your question or statement. To start viewing messages, select the forum that you want to visit below or click the board index to see a list of all forums. Thanks and have fun.
P500 Turf mode manual locking hub
Discussion in 'General Pioneer 500 Discussion' started by Chooglin, Jul 16, 2019.
  1. JeremieBaker
    JeremieBaker President of #NTC
    Jan 30, 2018
    10,796
    45,564
    Canton, OH
    Ownership:
    500
    When GPNWL gives you kudo's then you know you are a true artisan of the Honda!
    Bastardchild, trigger, Neohio and 3 others like this.
  2. Chooglin
    Chooglin Well-Known Member
    Vendor Lifetime Member Club Contributor
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Thank you , that means alot coming from you..........you're pretty damn crafty yourself!!!
  3. monaco
    monaco Well-Known Member
    Nov 18, 2016
    122
    264
    Indiana
    Ownership:
    500
    hahah
    trigger and Chooglin like this.
  4. monaco
    Nov 18, 2016
    122
    264
    Indiana
    Ownership:
    500
    But seriously. Love the locking hub idea and have been following. You can pull this off if anyone can!
    trigger, Chooglin and CumminsPusher like this.
  5. Bastardchild
    Bastardchild Well-Known Member
    Nov 3, 2016
    1,329
    3,996
    Orange Heights, fl
    Ownership:
    500, 700-4
    This thread gives me major bonage.
    trigger, Chooglin, monaco and 2 others like this.
  6. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Thank you
    It's been a "1 step forward 2 steps back" kinda thing so far ,but I pretty much have it figured out now...........Maybe :)
    Eltobgi, Gassygordo, trigger and 3 others like this.
  7. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Lmao...........its been giving me a headache!!!
    Gassygordo, Bastardchild and Mudwing like this.
  8. trigger
    trigger Old Ironsides
    Vendor Lifetime Member Supporting Member
    5,567
    15,164
    Ownership:
    500
  9. CumminsPusher
    CumminsPusher The woods made me do it,yet again!
    Lifetime Member Supporting Member Club Contributor
    21,289
    88,220
    Ownership:
    1000-5, Other Brand
    monaco, Bastardchild, trigger and 2 others like this.
  10. Choogsbro
    Choogsbro Well-Known Member
    Mar 20, 2018
    3,382
    18,156
    Monticello, Ky
    Ownership:
    Other Brand
    I think JTW has some.
  11. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Finished up the prototype parts and bench tested it and it works like a charm!!!!!
    This is the new spindle, which will bolt to the existing wheel hub on the machine and will use the stock lug nuts. The 6.00 dia. Flange with the wheel stud holes is not on this part but will be on the finished part. I chose not to machine the flange on this one to save some machine time and has no significance to the operation of the locking hub!!!!. There will also be matching splines on the end of the spindle that will fit in the locking hub.
    This is the new wheel hub with the new bearing pressed in it , this slide over top the spindle and is secured with a castle nut and cotter pin. Again, I did not machine the 6.00 dia. Flange on this either, just to save on machining time. It will also have the 4/110 bolt pattern with wheel studs!
    Next the wheel goes on the hub and bolted on with lug nuts.
    Now the locking hub gets bolted to the wheel hub.
    The locking hub does not protrude out past the wheel/tire either, wich I am happy about.......dont want to wack it with a tree and bust it off!!!!! :)
    So now I will order a piece of 7075-t6 aluminum for the new hub and a piece of 4041 for the spindle and start machining the final parts.
    #71 Chooglin, Aug 18, 2019
  12. Mudder
    Mudder Patriot Rider
    Oct 1, 2016
    3,233
    11,045
    Ownership:
    500
    Wish I had those skills. Thanks for the ongoing interesting posts.
    Mudwing, Bastardchild and Chooglin like this.
  13. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Thank you and you're welcome. It will probably be awhile before I post any new updates, I have alot of machining to do!!!
    CumminsPusher, Mudder and Mudwing like this.
  14. Bastardchild
    Nov 3, 2016
    1,329
    3,996
    Orange Heights, fl
    Ownership:
    500, 700-4
    That thing looks like a precision piece that belongs on the space shuttle engine! Excellent work Choogs!
  15. Bad_bowtie
    Bad_bowtie Huge member
    Jun 29, 2016
    1,262
    5,137
    East Tennessee
    Ownership:
    1000-5
    Simply amazing what some of y'all can do. Wish I had that skill set. Great job!!
  16. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Thank you sir
    Bastardchild likes this.
  17. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    Thank you , this happens to be what I do for a living (Machinist) so I enjoy this kind of stuff. I wish I had more knowledge in other area's, that many others have. This forum is a great place for all sorts of knowledge!
    #77 Chooglin, Aug 18, 2019
  18. Choogsbro
    Mar 20, 2018
    3,382
    18,156
    Monticello, Ky
    Ownership:
    Other Brand
    Nice work bro !!! Our old man would be proud. We owe him a bunch for sure.
  19. Chooglin
    Dec 2, 2014
    3,685
    10,619
    Mantua ,Ohio
    Ownership:
    500
    We sure do!!!!
    Russ989, Mudwing and Bastardchild like this.
  20. ToddH
    ToddH Well-Known Member
    Sep 4, 2018
    6,259
    32,381
    MI
    Ownership:
    500
    Your confusing this thread with the titty footage you edited out of your videos :D
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
    Dismiss Notice
Loading...
