P500 Tusk Electric Powersteering
Peter_72
Peter_72
792
6,533
Louisiana
My Tusk esp kit was delivered this afternoon! It was too late to get started on the install but I did open the box and have a look. The first thing I noticed is the Rugged name, I thought that was a different kit.
AD71FBEB 2A75 457E BE51 F21582D5DF81 C062614B E336 4BAF AD64 B99BB7BE0A45 959095F6 97AD 4008 87CB 0962A0DA6C58 7EEE431C CE07 494E A4CA 9BEECD3C25C9
Mudder
Mudder
NTC Ambassador of Walls
11,602
87,332
Likely different decal, same parts. One drive with the PS installed will make you forget about it. Great mod. Or time for a HondaSxS.com sticker.
Peter_72
Peter_72
792
6,533
Louisiana
Just finished installing it, I can steer it with one finger. I love it!
TIP for future installs: Don’t over tighten the mounting bracket! I had the 6 bolts that hold the bracket on too tight and it was hard to steer. I loosened all of them and it turns very easy now.
A
Avi8or
40
81
Mo
when you turn the wheel, does the motor and bracket move at all?
Mudder
Mudder
11,602
87,332
Was the motor wiring clip out the top or bottom? There was a problem with older instructions. Had to loosen the mounting plate to find the sweet spot to eliminate flex. @trigger and I had a similar issue with a @SuperATV unit a few years back.
Reactions: trigger
A
Avi8or
40
81
Mo
The flex I am seeing is on a new SuperATV kit I just received from Black Friday sale. I guess I’ll have to loosen up the bracket again to see if it will settle. I loosened it up once and slid it toward the drivers side and the wobble of the motor decreased, but it still moves some.
Reactions: trigger and Mudder
NitroxDiver
NitroxDiver
488
918
Concord NC
I found that when I first tightened down the mounting bracket it would bind up a little. To remedy this I loosened up the bolts a little so the bracket could move, worked the wheel back and forth to find the position the mount likes to be and tightened it down. Be sure to check the clearance between the steering shaft a brake master cylinder reservoir.
Peter_72
Peter_72
792
6,533
Louisiana
when I first installed it I noticed a lot of flex. After loosening the bolts and worked the steering and let it settle into place I tightened it back up andI was so happy it was working I didn’t look to see if it still flexed lol. I’ll take a look after while and post again
futzin
futzin
4,005
29,661
Kentucky
This is maybe a good time to bring up a glitch mine has done since install. Clearances look good, no rubbing; it does flex.
Issue is that sometimes, not very often, it binds/has resistance when turning left. It will usually 'release' with a pop/bang. Have watched it do it while sitting still; doesn't rub. Can't tell where the bang comes from.
Sound familiar to anyone?
LOVE the power steering; quicker through the woods (if ya want)!
Reactions: J80 and Mudder
173,627
Never had that issue, mine's been flawless. You may want to loosen up the shaft and see if you can find a happier place with less bind/flex.
Peter_72
Peter_72
792
6,533
Louisiana
I would definitely do as Trigger suggested and loosen everything up and see if it will settle into place. If that doesn’t work the manual does give a procedure in the troubleshooting section for poor steering in only one direction. I’ll have to read it again but it’s something to do with voltage. It might be sending too much voltage when you turn left
Peter_72
Peter_72
792
6,533
Louisiana
#2 explains making an adjustment for uneven power from left to right, I know it’s not your exact problem but it might be worth a shot
BF44CE62 6AA1 4E0A AB09 83F671A7E39E
futzin
futzin
4,005
29,661
Kentucky
Appreciate you putting that up. Yeah, the vast majority of the time it's perfect. The issue only happens occasionally. Our rides are typically around 20 miles; it may not occur on a ride at all. But when it does is you can tell, for sure.
Reactions: Peter_72
Peter_72
Peter_72
792
6,533
Louisiana
Avi8or I just checked and there is still some flex while turning in both directions. I read a review a while back that talked about the lower steering shaft bind (not rubbing) and the guy put a shim under the top plate of the mount and that cured his problem. I’m going to look into it more tomorrow.
A
Avi8or
40
81
Mo
Ok. Would be good to know.
I loosened the bracket again and turned side to side to let it settle and retightened. Still wobbles though
Mudder
Mudder
11,602
87,332
Second @trigger comment to loosen the shaft spline bolts to ensure no bind. Let them slide freely to see if it helps to rule out shaft length or bind issues. Should work without a shim IMO.
As a last resort. Remember when mount bolts are loose, mount plate might only settle in position of the last directional turn, not both. Try moving a bit, tighten and check, repeat.
As this is a common problem, seems like rubber grommets on mounting bolts would be good to cushion any residual flex stress. Any ideas @SuperATV ?? Thx.
Reactions: DaddyDubbs
173,627
Not understanding exactly what you're trying to do. The mounting bracket goes where the mounting bracket goes. I didn't shim or move anything. There will still be some flex on it but not to the point of binding the shafts. Loosen one shaft and turn in both directions watching the shaft slide, find the comfortable spot and tighten it back up. Should be good to go.
Reactions: Mudder
Peter_72
Peter_72
792
6,533
Louisiana
The shafts can’t be adjusted on mine, there’s a groove in the shaft where the bolt goes through. The bolt has to be completely removed to slide the shaft and if the slot is not lined up the bolt will not go back in. The upper shaft is made to move but it does so freely, no bolt in that spot so it’s always free to slide about an inch.
Peter_72
Peter_72
792
6,533
Louisiana
Just to be clear...the stock steering shaft was made the same way, bolts had to be completely removed for the shaft to slide
Reactions: Mudder
