BOX1
P1000 Tusk Terrabite 10ply air pressure
Scamih
161
425
Marshall Illinois
I just put on a new set tusk terrabite 10ply tires and rims.28x10x14, I ride on paved roads a lot with an annual trip to Tennessee to ride their great trails. What do you recommend for air pressure. What about tire alignment, slight toe in?
9AB6CC4F 6A6A 4AE3 84D2 6A2DC8FA4A0F
Dasmoeturhead
I run stock psi in the 12" terrabites I have, and they've been working good on the blacktop. My alignment is slightly toe in. Probably needs adjustment, but handles well.
Reactions: FJC 79 and Lady01
Dasmoeturhead
I've got 3,000 miles on them so far. Rubber is probably +50%. I use them 50/50 dirt/street. I'd buy them again in a heartbeat. There perfect for my use, not the best mudder, but if you get in a jam just make em spin. So far so good.🙂
I've got a brand new set of stock wheels and Blackstones in my shop. I figure if I want to hit the mud, I'd use them. I also use 1 for a spare.
HBarlow
HBarlow
1,599
5,955
Daniels, WV
Ideal inflation pressure for street driving leaves a full tread footprint on the pavement. Find a patch of smooth blacktop, wet the tread of each tire, one-by-one and roll forward or backward far enough to leave a wet footprint.
Examine the footprint. If print is narrow (less than tread width) the tire is overinflated. Bleed air accordingly.
If print shows outer tread edge but no center the tire is underinflated. Slowly inflate a pound or two and try again.
Lower pressure will provide a softer ride but too low may risk tire separating from the wheel bead with instant deflation.
TexasJackKin
TexasJackKin
387
3,128
Dayton, NV
In the picture in post 1, those tires look like they have directional thread (can't be sure since I can't see to whole thread pattern) if so, they appear to be on backwards. If they are all like that you could fix it just by swapping left for right..... I could be wrong, I often am....
HBarlow
HBarlow
1,599
5,955
Daniels, WV
Thanks, I’ll try that. They came installed on the rims at 12 which seems about right. I’ll check the coverage on pavement.
12 psi is probably about right. I think mine were at 13 - 15 psi.
Reactions: Rick53
Amitchellr
Amitchellr
61
249
Put the terrabite 8ply on pioneer 520 and run pressure machine recommends. Seems good.
BobFarrell
BobFarrell
129
275
Arizona
Had the Tusk Teribites on my 2011 RZR 800 & now have them on my 2021 Talon X2. 15# pressure all the way around seems to be right for me. About 90% time riding AZ dirt & rocks... 10% on asphalt.
wolf359
wolf359
64
403
Appalachia
I have about 100 miles on my new 10 ply Terrabites. Currently running 12 front 14 rear. I'm thinking that might come down a bit. I like the wet footprint idea from @HBarlow.
G
Gooseit69
48
106
Colorado
I just put on a new set tusk terrabite 10ply tires and rims.28x10x14, I ride on paved roads a lot with an annual trip to Tennessee to ride their great trails. What do you recommend for air pressure. What about tire alignment, slight toe in? View attachment 331875
Just wondering how much clearance you have and do they rub at full shock compression?
Reactions: Lady01
BobFarrell
BobFarrell
129
275
Arizona
I've got the same tires and ride mostly trails with some asphalt to get to them. I run 15 # all the way around. I left the alignment at factory. I've jumped it a little but the nose is heavy and it wants to land, front first so I don't do anything too Evil Knevil-ish...
All is good for me & no rubbing!
Reactions: Lady01
G
Gooseit69
48
106
Colorado
What is the diameter of the tire at 12 PSI?
BobFarrell
BobFarrell
129
275
Arizona
It's a 30x10R-15 tire. As such a 0 psi or 30 psi, it's 30" until the tread starts wearing down.
Reactions: CID and Lady01
wyogz
wyogz
11
23
Cheyenne, WY
  1. Talon x4
I just received my Teribites 31x10x15 for my Honda Talon 1000X-4, was thinking either 14 or 15 PSI all around?
Reactions: Lady01
207,936
That's a lot of air for around here..
BOX2
box3
