P1000 Tusk terrabite dot tires
A
arizonasteeler
23
40
mesa arizona
just wanted to give my initial review if anyone is interested, i bought them online from rocky mountain ATV for 428$ delivered i stuck with the 27 9 12's in front and the 27 11 12's rear they are definitely beefier than the stock tires maybe 5 pounds heavier per tire i'm just guessing, but for an Arizona street legal rig they are awesome i have about a 100 miles on them now and no complaints,60 mph highway speed smooth as glass i'm running 13psi right now but i'm sure i could run 10 psi no problem they are wearing good and work really well in the Arizona dessert. when i first got them un inflated they appeared really small but when mounted and aired up they where equal to or slightly taller than my stock tires i replaced. for the money i recommend the terrabites.
W
WireNut
7
10
Eaton Ohio
I have a set and there great for the road and light off road
Eltobgi
Eltobgi
4,599
15,186
North Dakota
How are they in the mud?
Reactions: Isaiah
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Just ordered a set of 28's! If I loose a little in the mud I guess I can live with that! Which rims are you running?o_O
Reactions: Isaiah and utvmi
Eltobgi
Eltobgi
4,599
15,186
North Dakota
28x10x14's just arrived today...
IMG 6524
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Rolled them up against stock bighorns and appeared to be the same sizeo_O
Reactions: Dp5hunter
eastenn
eastenn
220
469
Bristol TN
www.fb.com
IMG 0582 IMG 0581 Also, they're better than just "light off-road". I made it up some slick muddy hills in 2wd just to see how they would do. Very impressed. At 175 miles on mine I have noticed the fore and aft edges have started rounding over on the rear tires. I think that's from the locked rear diff though and probably 100 miles of that on pavement.
Dp5hunter
Dp5hunter
3,056
Hazlehurst Mississippi
View attachment 36158 View attachment 36159 Also, they're better than just "light off-road". I made it up some slick muddy hills in 2wd just to see how they would do. Very impressed. At 175 miles on mine I have noticed the fore and aft edges have started rounding over on the rear tires. I think that's from the locked rear diff though and probably 100 miles of that on pavement.
This is awesome information, I'm planning on going with the terabytes for the ROTC and send more info as u put more miles on yalls tires. ;)
Reactions: arizonasteeler
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Went for about a 30 mile ride today and noticed this...:(
IMG 6750 IMG 6751 IMG 6752 IMG 6753 IMG 6754 IMG 6755
Only tire which shows damage! Wondering if anyone else has had similar problems with this brand?o_O
Koda
Koda
565
2,309
Canton Ga
Eltobgi
Eltobgi
4,599
15,186
North Dakota
If that's on the front drivers side make sure it's not hitting at full turn
I didn't think about checking that! I will check tomorrow and report back! Thanks
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I hope thats not indicative of all their tires. I just put the same tires on mine.
They ran really smooth on the highway! Rode the ditch on the way back! I thought I was being careful for bottles and other debris, but I guess not! really not sure what happened to it! A little worried about the sharp rocks at the Takeover next month!
Eltobgi
Eltobgi
4,599
15,186
North Dakota
And I have a set of them coming to my house. :confused::eek:
Was hoping for an almost indestructible tire! I guess I will have to test them a little more and see if this was an isolated incident!
