P1000 Viper wireless winch controller
Soaz1000
Soaz1000
167
915
Soaz
Just finished installing my dual battery, fuse box and Viper 5000 winch on my 18 1000-5. Room under the hood is getting skimpy so I need some ideas on where to mount the wireless winch controller. Thought about mounting it on top of the cubby that’s below the warning label on the dash. I don’t think it should interfere with the rocker switches and wiring when I remove that warning label. Will the controller still pick up the signal mounted that far back? Also has anybody cut the gussets off the left side of the air box to mount their fuse box? I’ve seen pictures of them mounted there but I’m not sure if all years had those gussets. Thanks
Reactions: sharp
Dirtstiffs-1000
Dirtstiffs-1000
1,671
6,079
hondasxs.com
Here's where I mounted mine. Seems to work well and access to the remote turn on button is great.
20190601 142558
Reactions: 100Acre
Soaz1000
Soaz1000
167
915
Soaz
20190630 171957 Here's what mine looks like. The controller is temp till I figure a better spot. I wired the control temp just to winch the rope in. Is your fuse block mounted on top of the battery. I'm not to crazy where mines at.
AZRocks
AZRocks
111
217
Phoenix
I zip tied my wireless controller to the crossbar up under the black shroud just aft and above the AUX battery.
Reactions: 100Acre
Soaz1000
Soaz1000
167
915
Soaz
Thank you for the suggestions. By the time I got to the wiring stage it was around a 105⁰ in the carport and all I could think of was getting back under the A/C
Reactions: 100Acre
