BOX1
Vondy's 1000X-2 / Then 1000X-4 Builds
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
Also added SuperATV tailgate. Very happy with it. Mounts solid, no chance of rattling. Now to figure out how I want to mount rotopax.
5DDEBF7B A57A 456D 8CC9 E29C29948D68
6DF8C8C8 032D 45CE A5A5 3C96DE14FA2C
Lil_Steve
Lil_Steve
544
2,107
Gilbert, AZ
I have the same tail gate and moved my RotoPax mount from the JEI spare carrier to the SATV tailgate. Over 1000 miles so far and it's solid
MVIMG 20191116 130454 XL
MVIMG 20191116 130541 XL
MVIMG 20191116 130554 XL
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
Looks good. Thanks.
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
Did something stupid yesterday. Picked up a 4 seater to get the family out during the downtime from Covid. Keeping 2 seater as well for now, but it may need to go after this year.
F68F1022 87FA 4C73 A6B9 479B0839D12B
1B1A2F80 4C3A 4678 BAFF 6A71BD117935
3A34C827 5153 494F AF8A 593095E850BC
1F9034CD F839 434F BC64 475E1C142674
bionicman
37
49
seattle
which rims did you go with? look good. offsets? weights vs stock?
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
Swapped tires, soundbar, tablet mount, and rear clearance arms over to the 4 seater. Picked up some nerf bars on the way to Brimstone and installed when we got there. Had a great time and had no machine issues(note even the rzr's) Many of Brimstone's trails seem to be rougher than when we went 2 years ago. Had a great time and was great getting the whole family out now that we have 4 seats. Put about 100 miles on over 3 days there. Definitely need to upgrade the skid plate!
IMG 3724
IMG 3729
IMG 3730
IMG 3753
IMG 3754
IMG 3760
IMG 3762
IMG 3763
IMG 3764
IMG 3765
IMG 3770
IMG 3771
IMG 3772
IMG 3773
IMG 3774
IMG 3775
IMG 3776
IMG 3777
IMG 3778
IMG 3779
IMG 3780
IMG 3781
IMG 3783
IMG 3784
Hometeam
Hometeam
913
3,534
Normal, IL
Me and my boys love going to brimstone! Looks like you had a great time! Did you have any rubbing with your tires on Brimstone trails? I have considered that exact setup!)
Reactions: Mopower58 and Vondy
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
Minor rubbing at full turn when stuffed. Rubbed maybe 2-3 times the whole trip.
FOOTS
FOOTS
52
55
North Carolina
  1. Talon x4
.View attachment 203255View attachment 203256View attachment 203257View attachment 203261View attachment 203262View attachment 203268View attachment 203270View attachment 203271View attachment 203272View attachment 203273View attachment 203275View attachment 203276View attachment 203277View attachment 203278View attachment 203279View attachment 203280View attachment 203281View attachment 203282View attachment 203283View attachment 203284View attachment 203285View attachment 203286View attachment 203287View attachment 203288
That red hood looks good on there!! Sharp machine.
bigblueaz
bigblueaz
67
Arizona
Hi @Vondy been a while. would you mind a little flashback? I need to add a switch plate for the light bars and whips. Do you still recommend the switch pros Sp-9100? Also did you cut the plastic behind where you mounted the switch? Or just drill a hole for the wire? Since I have an R vs X, the area in the rear doesn't match any of your pics.
Anyone here copy Vondy here and find good mounting locations for the control unit?
Reactions: Vondy
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
Yes, I still have and really like theSP-9100. If you open the filter access cover in the bed, I mounted in the upper left corner. Your R will be the same as the X, there is no difference in machines in that area. I follow what another member done. This location is close to battery(directly behind) and great location for running wires up the roll bar to where ever needed or down thru the center of seats to the front end.
I drilled 2 small holes for the switchplate mounts and one a little larger for the control wire to pass thru.
I originally installed in my 2 seat talon and recently moved the entire piece to the new 4 seater. I used cheap amazon connectors to make it simple to add and remove accessories and also as a common ground.
- Switch Pros - Amazon.com: Switch Pros SP-9100 8-Switch Panel Power System With Concealed Mounting Hardware: Automotive
- Heat shrink terminals - https://amzn.to/2WobIdK
- 8 Position Terminal (1 used for accessories power) - https://amzn.to/2Wsdpa8
- 4 Position Terminal (1 used for ground terminal) - https://amzn.to/2EODbL1
- Ignition trigger wire - KEY ON POWER Harness for Honda Pioneer 1000, 700, 500, and Talon 1000.
Let me know if you have any more questions. This unit makes it so easy to wire everything. Eliminating all the fuses, relays, etc. It is also easily programmable to function in a lot of different ways.
bigblueaz
bigblueaz
67
Arizona
@Vondy This is from their installation instructions. Although water will not be an issue where you mounted it. I like how clean the terminal block is, seems odd they do not recommend using one.
I see yours shows the stereo, do you have the infinity connected through it?
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
My switchpro is not completely vertical but as it is mounted water would run out of connectors. Terminal block was my choice, may or may not be a good idea depending on riding style. Terminal block is cheap to replace if I see any corrosion. Fewer connection points the better I guess, but I like the way I did it. I also put another 4 position terminal block in front to easily hook in front accessories.
Main power for soundbar goes directly to the battery and there is a switch on the soundbar for that. I generally turn the main on for the weekend or then power up and down the unit thru the switch by the remote wire. Then keep the main switch off when stored.
Reactions: bigblueaz
ToolTime
ToolTime
38
99
Oregon
I am very impressed with the Switch pros wiring system. I was hesitant due to the price, but it was well worth it in the end. I would highly recommend for anyone planning on running 4 or more accessories or want the expansion capability.
The switch pros is so simple and easy to use. No relays, fuses, or fuse blocks. It is so versatile. With the switch pros Bluetooth app you can customize the amp ratings per switch, change between ignition and battery controlled, choose and infinitely adjustable colors on switches and so much more.
Copying the idea of another Talon owner on here, I mounted unit in the rear where you access the air filter. There was just enough room to mount it all up nicely and was close to battery. The 8 position terminal made for a clean installation and made it easy to add accessories. Used a 4 position terminal to hook up all the grounds and then grounded to battery. One communication cable was run up to the console where the switches are mounted.
Here is links to the switchpro and other materials I used.
- Switch Pro - SP9100 - Amazon.com: Switch Pros SP-9100 8-Switch Panel Power System With Concealed Mounting Hardware: Industrial & Scientific
Wiring Supplies
- Solder seal connectors - https://amzn.to/2MwXXFb
- 8 Position Terminal (1 used for accesories power) - https://amzn.to/2Wsdpa8
- 4 Postion Terminal (1 used for ground terminal) - https://amzn.to/2EODbL1
- Shrink Tube - https://amzn.to/31fqvqf
View attachment 124997 View attachment 124998 View attachment 124999 View attachment 125000
You sold me on this! I’ve been thinking this through and your post kept coming back up as a solution. Pulled the trigger on the parts today, can’t wait to put this in and put it to work. Nice work sharing your build, appreciate all of the links as a part of each step, very nice.
Reactions: Vondy
Prntckt
Prntckt
1,039
7,167
Altoona, WI
  1. Talon x4
Thought I’d line the toys up for a pic before the 2 seat talon gets picked up by its new owner.
I am debating buying a second machine. Considering a Talon X4. Wonder what your opinions are on the Talon X2 vs Talon X4? You’ve had both and been running the X4 for quite awhile.
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
Other than dragging belly I like the 4 seater better in most every way. Length makes climbing feel much more stable. Always felt like the front was light in the 2 seater. Length really doesnt seem to be a factor much in regards to turning radius almost seems similar to the R model. If I was going 2 seater again, I would definitely go with the R for stability and suspension travel.
Reactions: Prntckt
BOX2
box3
