U
So I was all set to install the rear shocks and then realized that it wasn’t going to be so smooth of an install. For one, the inserts that come with the shocks for the shock mounts only fit the threaded part of the Honda bolts through them. The non-threaded part is too thick (pic attached). The 2nd part is where to mount the external reservoirs. Think I found the best way to mount them. I used mounts from Amazon which I also needed longer screws to use an existing bracket. All the bolts/nuts I used are on the attached receipt from Home Depot. Hope this helps someone in the future...
Mount: https://www.amazon.com/dp/B01FETT3FO/?tag=sxsweb24-20
