Warn Axon 55S winch broken after 3rd pull
ehart814
ehart814
1,653
3,631
NWPA
Seems to be my luck to have dumb problems.
Sunday I got a call to help someone in our trails. I made a new hill climb, and it's a little sketchy. Well long story short, a friend thought they could make it and it didn't work out. So I get back there and find a General on its lid, wedged down in a small ravine.
I hooked my winch to his winch and tried to pull him over from behind his machine. Well the Axon would not retract the line. I was able to flip him back over by pulling in reverse. Luckily, he didn't get hurt and it didn't really mess up his machine.
So I messed around with the winch several times with no luck. When you press the "in" button, the light turns green. If you keep holding it, it will flash red.
Called Warn, of course it's under warranty. Well they tell me to call their service center. I call them, and they were very helpful. But, I have to remove the winch and mail it out. You can't take the thing apart without removing it from the machine.
It has not been used very much at all. I plowed snow 2 or 3 times last winter, pulled a log, and tried to use it the other day and it didn't work. I have never submerged the winch. I keep it clean. I would have been extremely irritated if I had gotten stuck myself and couldn't get out.
I bought the nicest, most powerful, and most expensive winch hoping to not have problems. Now I have to tear the dumb thing off and mess around sending it to a service center at my expense. I know, stuff happens. But I just wanted to let you all know about the problem because I'm not too excited about the Warn brand.
I even asked them to help me troubleshoot, and they did. I figured I'd rather just fix it if it wasn't super expensive. On the Axon, the electronics are pretty much all one part. The part costs $400, so if I do it myself that's what it will cost.
Reactions: Plumber32
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Bummer. It's a good looking winch but I haven't seen any reviews besides this on how it works. It's probably the only replacement I'd consider for my Superwinch Terra45 but I have 2 Terra45s so I probably won't need a replacement any time soon
69,248
The one we have on the wolverine an axiom 3500lb and its been a rockstar for 2 years now. I think it underrated. Swear it pulls better than my 4500lb superwinch. Probably a simple fluke your having issues.
ehart814
ehart814
1,653
3,631
NWPA
I love the Terra winches, and that's what I intended to buy from the start. But the prices went crazy when I was shopping. I used the crap out of my Terra 3500 on my 500 and never had a problem
ehart814
ehart814
1,653
3,631
NWPA
Well last night I finally got around to pulling the winch off. So I'll be boxing it up and hopefully sending it out today to the service center. Hoping this will be a smooth process with no surprises! If not, it will definitely the last Warn product I ever own.
Russ989
Russ989
22,642
147,257
I’m sure it’s some thing simple. I almost bought one but decided to save some money since I’d has such good luck with my viper on my 700. When I bought the 1000 I put a viper elite widespool on it and it’s been pretty great so far. I’ve not had to pull myself out but have made at least 13 recovery pulls, 2 of them were pretty brutal.
Reactions: wrhii and Plumber32
ehart814
ehart814
1,653
3,631
NWPA
I have debated about selling mine after it's fixed and just buying two harbor freight winches, one for a spare.
Reactions: wrhii and Russ989
Russ989
Russ989
22,642
147,257
You’ll probably never have another problem with it once you get it back. I’ve seen cheap and expensive winches fail. Might be luck of the draw.
Reactions: wrhii
sharp
sharp
3,757
14,955
Tennessee
The same thing is going on with mine except mine will only pull in. At least I can still free spool it out . It’s aggravating because when I spool it in I have to leave the line loose on the front. If I pull it in too tight it is almost impossible to turn the red release on the side of the winch. What a inconvenience to have to take it off and send it in.
Reactions: wrhii and ehart814
sharp
sharp
3,757
14,955
Tennessee
I wonder if you have to take all the wires off and send them with the winch? Or just send the winch in by itself?
Reactions: wrhii
ehart814
ehart814
1,653
3,631
NWPA
Wow that sucks you have the same issue. Is it an Axon?
At least you can pull yours in! Mine is completely worthless since it will only run out.
Yes, they told me I have to send in the wiring and switch so they can diagnose.
Reactions: Plumber32 and sharp
sharp
sharp
3,757
14,955
Tennessee
Mine is a Axon. Your right at least it pulls in. That’s most of the reason I’m too lazy to get out there and take it off. Lol
ehart814
ehart814
1,653
3,631
NWPA
Update:
I sent the winch to Hoak's Four Wheel drive (warn service center) on 7/16, and I just received it today. So one week turnaround, including transit time. They replaced the motor assembly, under warranty. Haven't installed it yet. Hopefully it works!
Hoak's seemed like a good business. I spoke with them on the phone and they were very professional and courteous, and they didn't make any promises they couldn't keep. And I am satisfied with the turnaround time. Thumbs up to Hoak's.
That’s discouraging. I have a new one in the box ready to go on. Hoping this works out for you.
Reactions: ehart814
ehart814
ehart814
1,653
3,631
NWPA
I vote you put the Warn back on and never have another issue.....🤞
Well that is the plan! But not feeling too warm and fuzzy about Warn after this order. But that's just my luck I guess. I'm just glad I didn't have my machine buried when I discovered the winch wouldn't pull!
I hope you have better luck with yours!
69,248
I installed a axon 4500rc haven't been able to test it. But the 3500 on my wolverine has been flawless. You'll be fine. They are a great winch.
Sure hope so, they’re expensive and look really cool. Now if it works great....👍🤣
Reactions: ehart814
cgibbons46
Louisiana
Seems to be a problem. Never used mine and first time I needed for a small job. Got the green/red light on pull with nothing. Axon 45-s
  • Sad
Reactions: wrhii
ehart814
ehart814
1,653
3,631
NWPA
Man that sucks. Sorry to hear that. I’ve used mine since it was repaired and it has been working well. It is really strong. It’s just a pain having to box it up and send it out. If you’re near PA send it to Hoaks. They did a good job and it was quick.
Reactions: wrhii
