P1000 Warn installed. Adding the dual battery set up - re wiring winch
raypa
17
9
Pittsburgh, PA
Hello all. I finally broke down and got the second battery and True isolator. I had my winch installed at the dealer and they used what appears to be the warn wiring harness. I haven't installed the second battery yet, I'm still waiting on parts.
Once installed, how do I rewire the warn wiring harness to pull power from the second battery rather than the main? I didn't see the original harness to know what is stock Honda and what is Warn. I've look through the site but wasn't able to find this exact scenario.
Also, what are yall using to strap the second battery down?
Reactions: sharp and Hondasxs
TripleB
TripleB
14,345
126,222
Caryville, Tennessee
Following. I've added the second battery and isolator. Working on my switches today. I think I know what I have to do to switch my winch but I'm not 100% sure. Maybe your post will help me out.
Mine is quite loose. Was going to use a rubber strap and self tappers.
Oh I figured that was why you asked, sorry, I was just messing around because mine is so tight....;)
Reactions: sharp
66,167
Hi. To answer this.
Really only the large winch wires needs be moved from the OEM battery to the second battery.
Depending on how its wired. You may just see the one red wire. The black wire may be hooked to the OEM factory winch ground.
I would recomend moving both the large red and large black to the second battery for full circuit isolation upon winch use.
I would not be concerned with the contactor control source as it's small draw.
BigOL3
BigOL3
2,994
8,920
Nothing. I put some 3/16 dense foam around battery and it is EXTREMELY tight fit.
Reactions: sharp
raypa
17
9
Pittsburgh, PA
I may do some plastic pipe strapping in addition. I just ordered the RC 50" DRL. I plan to mount it in front of my window tucked up under the roof ball cap. I didn't buy mounts yet. I want to position it and see where my options are. I "may" drill through the windshield to mount it to the rops. I would leave room so the window can pendulum out for ventilation. We'll see. Too hard to tell until it arrives. (Over $600 later, I'll have a new light.... (crazy))
I'm reading up on the winch wiring today to see what I have to swap. With the factory winch wiring harness, I'll have to separate it to swap the winch only to the new battery. I also bought a fuse block that I'll add at a later date for other stuff once I figure all this out.
raypa
17
9
Pittsburgh, PA
Thanks mjn for the help on this. Here is how I ended up rerouting wires to add the True after my winch was installed by Honda. Please note that I had to swap black and red wires due to length. I black taped my negatives so they didn't look red. Not ideal, but I wasn't going to make more runs to the store.
True Winch1
Reactions: Ar200
SLSHonda
SLSHonda
34
Florida
Where is everyone getting the wires that go to stinger, Curtis and fuse panel?
