P1000 Washing the P1's
208,730
Over the 2 more seats, P1-5 verses P1-3. I find it very handy to tilt the bed up, or do they both do it? Probably do. DUGH! Wow, it's takes time to clean one of these machines, It would be a real pain in the BUTT if the bed didn't tilt up. And with a full skid plate assembly, you need a fire hose. Any body got a short cut?
208,730
So no one washes there P1'S
Reactions: Hondasxs
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Not if I can keep from it.. LOL. Tilt up the bed and pressure wash the hell out of it..Wait a bit....Then hit it again. Joey uses some stuff called super clean think it's made by Castrol.
Reactions: AKRider
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Pressure washer and a few hours of your time. Super Clean definitely helps after you get all the big stuck on stuff off and out of it.
For those of us on well water, I used a three-quarter inch hose with a high flow nozzle tied in to the main line right off the expansion tank which is inch and a half. To have that much volume and 70 psi, it really cut down the time required for washing.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Normally I'm a "spray and pray" kinda guy with the pressure washer. But last few times I've gotten a code for low voltage at map sensor. So be careful around the electronics. Still waiting on time to tear into it and address the map sensor plug and waterproof it.
Reactions: AKRider
Manwell
Manwell
803
2,439
I've used my pressure washer with pretty good success, however I'm not really all into having a spotless off road machine! Even back in the days when I did a lot of motorcycling, I didn't waste much time polishing, spent more time eating up miles!
tig
tig
116
176
I've had good success lifting the front of the machine up where the front tires are ~3' off the ground. Lets you get a good upward angle on stuff and mud/water runs off the skids. I go over the machine with a low pressure hose to wet things out and wash the actual mud off, after that I go back over it with the pressure washer to get the dirt "film". I've also used a fire hose once. That worked awesome.
Reactions: sharp and AKRider
txsurfer
txsurfer
496
990
Santa Fe , TX
well it takes me 3 hrs to wash my boat so the the pioneer seems pretty easy.. then again i'm not trying to get crazy in the mud
Reactions: sharp and JTW
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
While I have not tried this myself I have seen some before and after pics where sprayed with a solution of
1/2 cup Zeb Fast 505 degreaser
1/2 cup Tide clothes detergent
to a gal of water
Spray machine, let sit 5 min and them pressure wash off- the before and after pics I have seen look great and I plan on trying soon.
only a little concerned about the degreaser and if that will doing anything
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
On another note - what is a good power washer to look at buying?
Markbama
30
12
Millbrook AL
Be careful with your pressure washing...it has a tendency to force water into cracks and crevices that are sensitive to water...sometimes more pressure and force is a bad thing.
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
I just use a cheap electric washer.. we've got a big Honda washer but it's too much.
I am looking for one that I can use on the P1k but also use for other things around the house - Driveway, siding etc. Granted it will probably be used more regularly on the Honda
sharp
sharp
3,757
14,955
Tennessee
For Around the house and cleaning the rig you might want to look into a 2000-2500psi pressure washer,
Reactions: JTW
The little electric is perfect for the sxs.. I think mine is 1700 or 1900 psi but it's not got enough s*** for house type stuff. The big Honda washer is a beast, it's a 3500psi commercial unit dad bought years ago. It's heavy and will eat stuff up if you're not careful. No more than the electric units are and as light and easy as they are to use.. I'd would suggest getting one if all you use it for is the sxs.
Reactions: sharp
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
I've got a cheap harbor freight power washer. I love it, and it works great on the Pioneer. My favorite way to wash it is by sitting in a lawn chair and drink a cocktail while the neighbor kid earns 25 bucks.
Neighbor kid?? Don't you have a bakers dozen worth of your own?
