Weller Racing Springs
hondabob
1,158
4,522
Prescott Valley, AZ
My Buddy got the Weller Racing Springs and valving. The Quick Switch three controls the high and low speed damping. They soften it up a bit. I ordered the rear spring set and will do a comparison. I have 14,600 and some miles on mine. It looks like the bottom spring is the soft one then it crosses over to the upper spring but I'm not sure. My tender springs may need to be replaced. They will have a spring kit with cross over rings for the Talon X in a few days.
25017
25018
25020
25021
Dunegod
Dunegod
23
30
Mesa Az
I have a complete set of Wellers springs for the R. Shoot Me a PM if interested.
$280 + shipping for the complete set.
hondabob
1,158
4,522
Prescott Valley, AZ
I will get my Weller springs on Wednesday and will be testing this week. If I like the springs I will buy your complete set for my 2020 Talon. I see you have a turbo so I expect you ride fast and the Weller springs may be to0 soft. Several of the guys I ride with need a super soft ride or they need a couple of days to recover. I slow down for the huge whoops and we don't have many where I ride but lots of wash board and rough rocky desert and forest roads.
Dunegod
Dunegod
23
30
Mesa Az
Thanks Bob I will wait to hear back from you.
IDIOT
IDIOT
279
751
Kingman, Az.
Looking forward to your review.....
Dunegod
Dunegod
23
30
Mesa Az
Still have a complete set of Wellers springs for the R. Shoot Me a PM if interested.
hondabob
1,158
4,522
Prescott Valley, AZ
The Weller Racing rear spring kit makes a good improvement. I'm testing on a 60 mile loop that I usually don't ride because its so rough and with large water bars. I had to add more preload with my Motorcycle in the back. The additional weight is around 130 pounds and its centered at the end of the bed. I'm still testing and comparing it with my 2020 Talon R with the tender spring cross over rings set to near tender spring coil bind. Both have the sway bar removed and that makes the suspension better especially in the rocky sections. I should get done testing sometime next week.
20200516 114115 resized
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Weight and G force is a killer. from the pics and description, could use a longer upper spring to play with the crossover more to keep the softer ride,.
Reactions: CID
hondabob
1,158
4,522
Prescott Valley, AZ
Those are the stock springs in the motorcycle picture. The Weller springs have a smaller wire diameter and the tender spring is longer. I tested my stock 2020 Talon R today with the tender springs near coil bind and it is pretty good and probably good enough for many owners. I removed the sway bar on both Talons. The Weller springs are noticeably better and I expect they will be way better in the sand wash washboard. 4WD also helps in the sand wash washboard too. To find the 40 to 70 mph long whoop sections I would have to go to California desert or find an old race course. The Talon does great for all my riding. The guys with the Talon X all need the spring kit upgrade.
hondabob
1,158
4,522
Prescott Valley, AZ
I'm going to do some sand wash washboard testing next and have a few places to check in the North. I may have to go to the desert when we get a below normal temp. I run 9 psi in the front tires and 11 in the rear. For high speed rides I run 12 and 14.
Reactions: CID
5,015
22,380
Tagging @my99svt - he just got his back from Weller as well
@my99svt Did you get the valving done at the same time? How did you define your riding - high speed/racing or (softer) trail riding? Care to share the cost?
Reactions: CumminsPusher
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
Yes, Weller worked some magic on my suspension. I sent them off and they did both valve work and new springs. Trails we ride are mostly 5-25mph. Sometimes faster, no racing. The cost with schraeder valver was a little over $1400 Rides about the same from 0-10mph, 10 and up is amazingly smooth!
TerryH
TerryH
664
2,241
Springdale, Ar
You doing the Weller stuff on the X?
5,015
22,380
Yes, just waiting on Weller to tell me to ship them!
Got pics of how you packed them - I don't have a clue? I'd probably buy a pallet and stuff 'em between the top and bottom layers. o_O
Lil_Steve
Lil_Steve
544
2,107
Gilbert, AZ
Weller is local to me as is ST, so if you still have plans on heading to the desert maybe you can schedule dropping the car off to them.
my99svt
my99svt
1,267
5,248
I removed the springs to save bulk and weight. Then I just took it to a fedex place and they packaged it. Wasn't cheap. They provided boxes and it was $150.00
5,015
22,380
Ouch, :oops: makes my pallet idea look 'reasonable' - or not.
Cool, :cool: that'll work. 👍
