P500 What style of riding makes Walker Evans shocks worthwhile?
gmacaluso
gmacaluso
114
162
Colorado
UHMW skids, a-arms guards, and rockers installed! Contemplating my next investment. This time in tires, wheels and shocks ... hopefully to gain some travel. Need to know if my pretty deliberate style in climbing tall mountains would benefit from Walker Evans. Do W/E shocks alone add lift/travel? Suggestions I've heard to date is they are worth the investment at higher speeds but that really doesn't describe my style.
Reactions: Tony21
JCart
JCart
895
2,021
Kamloops, BC Canada.
Can’t specifically speak for W Evans, I can say that stage 3 Elka shocks/springs made a significant change for the better, combined with Radial tires is the ticket. I went with Kenda HTRs in 27 by 11 by 12” on all corners with 5-2 offset rims, these combined with the Elkas made for a solid 2 gears quicker on most trails. The difference is expensive but in my case worth the cost. Really changed the machine for the better, I mostly ride forestry logging roads, old rough trails.
Cheers.
182,042
You won't get lift or extended travel. You can crank the preload on the springs, might get some out of it but just makes for a stiffer ride. I've also noticed that if you lift the front too much you'll start messing with the camber of the wheels, tops will tilt out. With all that said they're still awesome! It's more about the rebound, way better feel and control.
Got them for the front, had to talk a lot of sh** to the wife to justify the price. After the first ride she said I should get them for the rear. You know it's not placebo when they tell you it rides better.
gmacaluso
gmacaluso
114
162
Colorado
Cheers.
J,
Thanks for that ... describe "2 gears quicker" for me. I presume no spacers then on the 5-2's? Nice wide track on all 4 corners ... what psi?
G
Reactions: J80
JCart
JCart
895
2,021
J,
G
No spacers, just touches on compression (front fenders, as I have custom fender extender mud flaps). Typically run 6 psi front and 8 psi on the rear. About 54” wide as I recall.
The 2 gears quicker refers to: if on one of your known traveled trails you are in 1st gear, with above combo 2nd or 3rd gear is easily attainable..... significant improvement in ride and handling.
Cheers,
j
spartner
23
39
Spokane
I installed WE shocks on all 4 corners a few months ago. The main reason was that the stock shocks would bottom out from time to time and that is a tooth jaring experience. My main reason for switching to WEs was hoping to stop the occasional bottoming out. I am happy to report that the WEs have not yet bottomed out. That alone makes them worth it for me. And they are extremely easy and quick to install. Now, in addition to no more bottoming out on rough rides, the WEs make for a smother, more comfortable ride over all. I am very happy with them and think the change out was worth it.
Red500
Red500
6,146
66,494
Greeneville, Tn.
Instead of how much faster can you ride. My question is how much longer can you ride before you feel like you can't take one more jolt. We rode for several hours this weekend and by the end it just wasn't fun anymore we just wanted to get off the trails and go home.
spartner
23
39
Spokane
I go riding with others when I get the chance to go on a ride, usually once or twice per month. Generally, it is in the mountains of Northern Idaho. Most of the rides rarely go above 30 MPH and are mostly 10 to 15 MPH. So, I don't usually go fast. Most of our rides are 4 to 5 hours long. I have never felt like I wanted the ride to end either before or after the WEs were installed. The WEs do make for a more stable feeling ride but the greatest improvement, from my prospective, is eliminating the jarring bottoming out that I used to get with the stock shocks on a really rough trail or the occasional whoops where I landed a little hard. A rough trail is still a rough trail even with the WEs. Some have discribed the ride with the WEs is like riding in a Cadillac. I think that is a bit of an exageration or they ride on a lot smother trails than I do.
futzin
futzin
4,288
31,770
Kentucky
Personally speaking, I'd have to experience them on a comparable P500 to mine before I'd pull the trigger on them. I'm not unhappy since removing the anti-sway bar and installing 27s (on 4+3 offset 12" wheels).
Great topic.
182,042
How much longer you can ride will vary depending on the rider. Have done all day rides with both and have felt beat down with both depending on the trails ridden. The WE's definitely absorb the shock better than the stockers. Are they worth the hefty price? They were to me but so were a lot of expensive items I've added. Can't remember anyone saying they were not worth it though either.
gmacaluso
gmacaluso
114
162
Colorado
I'm in a place where I think the stock shocks are fine and wonder if the WE's juice is worth the squeeze. If it is a ride-comfort thing exclusively ... I probably don't need/deserve it. If they provide even marginally better control and stability (in feel) then they would be worth it to me. I don't generally say at the end of a ride "that track beat me up". So safety, control, stability, now that I know that the shocks add no additional travel, would make the purchase worthwhile IMO. Smoothing out the tough trails for comfort ... probably just an added bonus.
If that is the case, would you all say the purchase more than met your goals for safety, control, stability (over the stock feel)?
Reactions: Mudder and trigger
182,042
I recently bought shocks for my truck, in fact been waiting on the rears and they just showed up today. Replacing the stock Rancho's with Bilstein 5100's, supposed to be German engineered and really good shocks, we'll see. Anyway, found it ironic that I got all 4 for $364. Granted they're not coil overs or adjustable but they're for a 3/4 ton truck!
gmacaluso
gmacaluso
114
162
Colorado
and what does a set of WE's go for a 1000 lb p500?? :)
Reactions: trigger
273,037
Screenshot 20210310 202315 Chrome
Off road riding of course.
Reactions: Red500 and trigger
