What tube to use as a back up?
PhilCod
PhilCod
354
729
Indiana
I was thinking about buying a couple of tubes to have to put in a tire if I run into a hole or gash I can't fix. I'm running stock tires/Rims on my Talon X. The tires are 28x 9 and 28 x 11, both R15. I can't seem to find tubes the same size of the tire. Or do I need them smaller? I've never messed with putting tubes in. I have had a tire shop put them on my RZR one time. Useful input would be appreciated. Thanks!
PaulF
PaulF
1,462
4,815
28X9X15 is approximately a 225/75-R15
28X11X15 is approximately a 275/60-R15
The MR-14/15 tube is the closest you will find that will fit both tires. It will certainly do in a pinch to get you home...
Oreilly even has them...
PhilCod
PhilCod
354
729
Indiana
Thanks!! That is what I needed.
Reactions: Isaiah
