I'm sure this has been asked 1000 times but my search doesn't work. When installing aftermarket wheels I see most sets are not staggered like factory. What spacer installed where will keep the track width the same front and rear?
Most do 1 inch on the rear. U don't have to use any. Unless you're a dead eye dick, u can't really notice the difference unless u pull out the tape measure.
I'm no expert, but I believe the stock front offset is 6+1, so a 5+2 puts you 1" further out. The rear stock offset is a 4+3, so a 5+2 leaves you 1" in. So the 1" spacer kinda evens you out, again i'm not an expert just what I have read + or -.
